Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. 8pack
    2,623
    149
    Aug 29, 2007
    Western, MA
    Thanks, hopefully someone will weigh in who has used one. Just in the planning stages. Seems like a better option than replacing the fuel tank but my engine compartment is pretty crowded.
  2. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
  3. legierk
    legierk Veteran Member
    762
    Jun 11, 2014
    Waskom, TX
  4. BigBlock73
    2,051
    61
    Jul 10, 2002
    Accord,New York
  5. BonzoHansen
    19,494
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    that is a separate part. the aeromotive phantom setup would be separate form the gauge sender too.
  6. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Personally, I like my EFI gas tank...seems a lot easier to me than installing all of that Fuel Command Center and trying to find room to mount that stuff up near the motor somewhere.
  7. BonzoHansen
    19,494
    824
    Jun 1, 2005
    that is the only way to go IMO
  8. BigBlock73
    2,051
    61
    Jul 10, 2002
    Accord,New York
    I'm leaning towards getting the tank
    What did you use to connect the tank to the EFI ?
  9. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    The command center on our cars is not the way I'd recommend to anyone.. there is really no good spot unless you want to relocate something else.
    I went with a tanks inc tank and running a single hose from the tank through a corvette filter and single hose to the engine.. best way to go
  10. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    If you read (and it's a heck of a long read) through those Chevelle forum threads posted above you'll discover that many, if not most of them ran into issues with their command centers. In the beginning of the thread they all seemed to be in favor of the command center but that changed as they lived with them and problems arose. The most recent posts favor the EFI fuel tank setup. There was a similar story on a Corvette thread I saw as well. Basically the command center sounds like a last resort if there is no way to convert your tank to EFI.
    You can get the plug-n-play tank/pump setup from Tanks Inc. for about $500. Seems a bit pricey especially if you already have a good tank. Is there a cheaper way that is just as effective? I'm thinking that one of those PA-4 retrofit kits along with one of their 5-bolt sending units should be all the hardware you need. A little modification to the tank along the lines of the video they have on the site and you have an EFI tank for under $300. Am I missing anything?
