Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    Yes, that's the one. Seems like they strapped a feminine napkin to the pump inlet. I guess it could work...maybe. I'd still be worried. Still too expensive though.
  2. 8pack
    2,580
    144
    Aug 29, 2007
    Pittsburgh, PA
    OK. Going to order up a Fitech this week. Any better purchasing path? Summit vs. Fitech directly? Also going with the RobbMC Power Surge Canister. Wrote Rob a note with a bunch of questions and he wrote back right away. GREAT Customer Service as always.
    Also, happy to take advice on the following:
    What size fuel line and fittings are you running from the Throttle body to the Command center for those using the CC(Power Surge Canister)...6AN or 8AN?
    I was planning to mount the canister where the Charcoal canister was. Any suggestions on fuel line routing? That means the main feed from the mechanical fuel pump to the Power Surge has to come across the engine bay somehow and over the left front corner. Maybe the bottom of the block instead of up and over the top? I have AC so there is no room to put the canister on the passenger side that I can find.
    Any other advice welcome. I have spent quite a bit of time on the Chevelle site and it looks like I will have a little tuning to do given my cam....
    Thanks!
  3. redriderjf87
    redriderjf87 Veteran Member
    131
    11
    Jan 23, 2016
    Quad Cities, IL
    Thanks, that video pretty much answered all of my questions I was going to ask on installing the PA retrofit module. Now I can get to work :)
    NeoNeuro likes this.
  4. JKC
    JKC Veteran Member
    104
    Jul 12, 2014
    Knoxville Tn
  5. stoney2677
    stoney2677 Veteran Member
    172
    Oct 6, 2007
    metuchen, nj
    Does the hand held read your motors vacuum?
  6. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    I poured through all their documentation and I don't see any mention of it. I asked the question on their website. I'll update when I get an answer.
  7. Itsadryheat79
    Itsadryheat79 Veteran Member Lifetime Gold Member
    308
    Aug 4, 2009
    Chandler, Arizona
    IMG_7919.JPG IMG_7920.JPG Pics are from SEMA 2016
    Edelbrock has a new sump like the command center. It's fuel sump is plastic and looks like it would fit better under the hood. It does not require a return to operate but a return line can be used according to the head engineering tech that demonstrated the system in their booth. The touted advantage to a plastic sump is it will not absorb the heat like a metal sump.
  8. BonzoHansen
    19,287
    693
    Jun 1, 2005
    Scott from Hamilton, NJ
    I mentioned that many pages ago but was shot down over price
  9. Itsadryheat79
    308
    Aug 4, 2009
    Chandler, Arizona
    IMG_8007.JPG @ SEMA I found it interesting FITECH was showing their new in tank fuel plump kit called the "G-Sump" and did not have the Command Center on display in their booth. When asked why I was told they decided not bring it due to the booth space.
    John Wright likes this.
  10. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    Looks remarkably similar to the Holley system.
    I suspect there were other reasons they didn't display the Command Center. A ton of guys have posted around the net about problems with those. Too bad too. Looks like a great and affordable option to an in-tank pump, if it would work.
