Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    I got a response from FiTech. Yes, it displays manifold vacuum.
  2. stoney2677
    stoney2677 Veteran Member
    172
    Oct 6, 2007
    metuchen, nj
    Cool, thanks man.
  3. 71RS/SS396
    71RS/SS396 Veteran Member
    2,627
    30
    Aug 26, 2008
    Wake Forest NC
  4. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,195
    39
    Dec 18, 2007
    Camaro Country,GA
    Finally got my FITech 600HP on my 383 and running with the FCC (Fuel Command Center). Everything starts nice and drives a lot better than the Holley 770 carb that was on it. There are a couple of issues I need to address is my drop down 14 air cleaner won't fit with a 90 degree fitting in rear of EFI. Any ideas ? The other issue is that I have a slight stumble off idle. Upon researching I found that I may need to adjust my IAC to 6 to 10 counts. Car seems to have more power than the Holley did--seat of the pants feel. Car will be put on dyno to see what difference I have before and after. I will later run steel braided lines for all the fuel hoses.
  5. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    Use a carb to air cleaner spacer.. any parts place has em for a few bucks.. I used a 1 inch one..
  6. stoney2677
    172
    Oct 6, 2007
    metuchen, nj
    There's an insane amount of info on chevelles.com. Prob better support than calling Fitech themselves. Apparently there's a lot of changes that can be made to these to fine tune.
  7. earnhardtgm3
    3,195
    39
    Dec 18, 2007
    Camaro Country,GA
    Yes
    I have been reading thru all the postings. Some very good info indeed.
    I will try the carb spacer first then I may try one of these.
    http://www.ebay.com/itm/Quick-Fuel-19-2-Swivel-Banjo-Fitting-Hose-3-8-Thread-9-16-x-24/200707695013?_trksid=p2054502.c100227.m3827&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908103841&meid=b8934725499f4b21bb04dce7d511b082&pid=100227&rk=1&rkt=10&sd=200707695013
  8. BigBlock73
    2,051
    61
    Jul 10, 2002
    Accord,New York
  9. earnhardtgm3
    3,195
    39
    Dec 18, 2007
    Camaro Country,GA
  10. earnhardtgm3
    3,195
    39
    Dec 18, 2007
    Camaro Country,GA
    Where are you guys mounting the Handheld Display unit for monitoring?
    Right now for the moment,mine is laying in the console opening.
    Was thinking about some sort of cell phone holder. Any Ideas? Or post what you did.
