Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. BigBlock73
    2,055
    61
    Jul 10, 2002
    Accord,New York
    That one doesn't come with the banjo bolt,sold separately.
  2. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    Yes it does
  3. dailycruiser81
    207
    10
    May 19, 2013
    ft lauderdale
  4. dailycruiser81
    207
    10
    May 19, 2013
    ft lauderdale
    Nevermind. Not thinking straight. Used tanks ink tank and pump set up
  5. earnhardtgm3
    earnhardtgm3 Veteran Member
    3,212
    39
    Dec 18, 2007
    Camaro Country,GA
    Finially got mine tuned and runs/starts just fine. Anybody use the FITech software to tweak their settings. The shop that did mine got a copy.
  6. Racer X
    Racer X Veteran Member
    442
    Aug 26, 1999
    NJ
    :mad: Well I had it with the command center so I finally fixed it!:D
  7. Racer X
    442
    Aug 26, 1999
    NJ
    :) IT WORKS!
  8. BigBlock73
    2,055
    61
    Jul 10, 2002
    Accord,New York
    That's the the way the RobMc tank works
  9. Racer X
    442
    Aug 26, 1999
    NJ
    Testing the Efi a bit I never beat on my car and never hardly floored it so the efi probably did not learn the best for being floored... sorry about the sound it's not the best.
  10. Plant Engineer
    Plant Engineer Veteran Member
    388
    99
    May 17, 2017
    Fort Mill SC
    Ive been running the 1200 PA unit on my 11:1 496 hyd roller with AFR 265 CNC heads . Drove me nuts the other day after my alternator crapped out. Changed the alternator and it started doing the cutting out thing. Couldnt make it around the block without dying and it kept me from racing last week. Tried all the "fix"s on the internet even the ones that made no sense at all like running a separate ground wire to the throttle body . I isolated the fuel pump with a relay, cleared the learned stuff etc. Still kept dying . I was about ready to use the thing as target practice then I thought " what would I do at work if I had a PLC that had a major fault and had ongoing glitches afterwards even though the base programs arent supposed to get corrupted? " Since the fitech is basically a PLC with a device attached I reloaded the base program , set my user options and it took off. drives like a dream now.
