Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. Racer X
    Racer X Veteran Member
    442
    Aug 26, 1999
    NJ
    Wow that's crazy but a good thing... how do you reload the stock program?
  2. BonzoHansen
    19,439
    797
    Jun 1, 2005
    Scott from Hamilton, NJ
    I met a guy last weekend that had similar issues. It would run fine for a few weeks, then all or the sudden it would start acting up. He said resetting it takes care of the issue for another few weeks. Sounds like efitech support was a bit stumped on it.
  3. Plant Engineer
    Plant Engineer Veteran Member
    385
    99
    May 17, 2017
    Fort Mill SC
    I tried resetting the learned stuff a few times and it didnt work. On a lark I reloaded the base program and it worked fine. In my case it all started after my alternator crapped out and the voltage dropped low. Hopefully I dont have to do it again but at least I know where to start. In my case its 30012 model but yours is probably similar.
    Main Menu>11.Write Cal to ECU>Default V8 T1950 30012 201609
