Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. CasperCasper
    CasperCasper Veteran Member
    1,071
    176
    Aug 11, 2015
    I think where you have it is just fine. Run the line from the tank along the inner fender to it, and run the line to the motor along the inner fender, then firewall and into the throttle body from the back. Keep fuel lines far from that spinning stuff. Doubt you'd see any big fuel pressure drop doing it this way.
  2. jvle95
    jvle95 Veteran Member
    191
    14
    May 14, 2007
    SF Bay Area, CA
    Mount the battery in the trunk and then place the FCC where the battery goes?
  3. junkyardZ28find
    785
    8
    Mar 4, 2012
    des moines, iowa
    I really like the looks of that EFI unit....appears to be an all-business upgrade....almost evil looking!
  4. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    It's a nice unit for sure. Just sucks that the center is limited on where it can be.
    It's not worth moving my battery though.
    I think I will end up making room on my passenger firewall unless I figure a better way to make it work where it's at
  5. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    I would run steel fuel lines along the front of the engine crossmember and the top of the subframe to the command center.
  6. Enroute
    Enroute Veteran Member
    695
    Nov 1, 2001
    S. Ontario
    I would make every effort to keep the FCC on the passenger side of the car.
    If the space is needed for the FCC I would relocate the battery to the driver side.
    I would rather run a battery cable across than a fuel line.
  7. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Very good information and thoughts. I think I know own what I will do thank you
  8. ProjectCam76
    ProjectCam76 Veteran Member Lifetime Gold Member
    275
    Aug 10, 2015
    Birmingham, Alabama
    I've kept up with this thread and that sounds like a pretty good idea.
  9. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,980
    May 22, 2001
    Carmel, NY
    I've been considering the FITech for my 79z also. It looks good, its simple, and works well from what I've read.
    I just hate the idea of mounting that FCC in the engine bay. I'm all about cleaning up the engine bay. It takes up a bunch of room and certainly stands out.
    I think I'm gonna go the fi fuel tank route and avoid that gawdy fcc when I make my move.
  10. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    I should have went with a efi tank. And agree don't want much in my Bay area.
    I will most likely put here heater core was and move a few things around or move battery to other side and put in its place
