Knockoff Knockoff Intake?
Discussion in 'Engine Topic' started by Rustbucket350, Jan 4, 2015.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Summit usually keeps a close hold of their house brands. I suspect that it can always change too. If I had to suspect, I don't think they are Weiand, they are likely as you suspect Procomp or similar
    FWIW, I went to Harbor Frieght the other day and bought a dial indicator base, brought it home...it was EXACTLY the same as the one I bought from Summit. Summit is not against overseas made products. Just like anyone if the quality is good the value is good. Never had a problem with a Summit Branded part.
  2. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    So ProComp changed their name eh? Odd that a company would change their name if its a quality company. I don't recall Holley changing their name...or Edelbrock, or ARP, or....
  3. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Maybe an owner change who didn't want to be known as "Pro-Comp"? Or the name was trade-marked by someone else forcing a name change. I know I would likely change the name. Forums like these put their products through the mud not ever using them. MOST people would not even know they are the same company.
  4. bygblok
    bygblok Veteran Member
    769
    Nov 28, 2010
    Pensacola Florida
    I had the Jegs "knockoff" of a performer RPM sitting next to the real deal and couldn't tell them apart from each other except for the ugly edelbrock logo on the real deal. I powdercoated it black anyway so the choice I made at the time was the jegs since there was no grinding needed to clean it up. It worked perfect, never leaked and it's still sitting here ready to go back to work when I tell it to.
  5. Rustbucket350
    Rustbucket350 Veteran Member
    865
    35
    Sep 4, 2013
    Oviedo, Florida
    Yes, it probably was due to bad press. At the end of the day, junk is junk. You can put a "Made in USA" stamp on it and cover yourself by telling the customer to hog the ports out in the instructions, but that doesn't make it quality junk. In fact, I'm looking at a GM Performance polished aluminum water neck right here in my lap that says "Made in Taiwan". Why did I pay extra for that?
  6. Rustbucket350
    865
    35
    Sep 4, 2013
    Oviedo, Florida
    Looked up the part number for the water neck (141-500) to find out the GM one is a Proform part. GM obviously has no problem with offshore parts. This is getting off topic though. The intakes will be here later this week and I'll do a review.
  7. Johnny Blaze
    Johnny Blaze Veteran Member
    930
    27
    Jan 24, 2013
    New Washington, IN
    Nuff Said!
  8. rtanner
    rtanner Veteran Member
    177
    May 29, 2010
    fairfeild texas
    AMEN bro, wish guys would stay on topic
  9. ddeennis
    ddeennis Veteran Member
    1,601
    Feb 12, 2003
    winfield
    You will find the knock off intakes are down in power across the board, example eddy rpm air gap makes more power thru the curve then the knock off air gap, same goes with victor intakes and the counter part knock offs.
    I'm selling my one and only knock off I bought, none of the threads was good in the intake ( yes it was new out of the box) pro comp air gap knock off for vortec heads, junk junk junk, for a few bucks more I could have gotten the real eddy rpm air gap which I'm sure would have had good threads plus I would have gotton more overall power.
    I bought first to save a few bucks, then when I got it had issues with threads
    and found out ya they are junk and they can not produce the same power as the real design.
    I'm not sold on the knock off crap, it's the original designer from here on out, name brand company's.
    That's my take on them.
  10. Rustbucket350
    865
    35
    Sep 4, 2013
    Oviedo, Florida
    Can you post a picture of the ports on your knockoff?
