L92 mounting?
Discussion in 'High Tech Retrofits' started by CaliCamaro75, Dec 11, 2019.
  1. CaliCamaro75
    CaliCamaro75 Veteran Member
    415
    24
    Sep 6, 2015
    Winchester,CA
    What else is needed to mount for mock up besides these? First Swap and did the rookie move of selling / tossing parts I thought I wouldn't need. s-l1600-9-1024x1024.jpg
  2. badazz81z28
    16,983
    521
    Las Vegas, NV
    You need engine mounts. Those brackets attach to the LS block so you can mimic the bolt holes from the SBC. The motor mounts or brackets depending on the year (early or late sec gen) bolt to those brackets
  3. CaliCamaro75
    415
    24
    Sep 6, 2015
    Winchester,CA
  4. badazz81z28
    16,983
    521
    Las Vegas, NV
    No, that’s an actual motor mount that would interface with a stand.
  5. badazz81z28
    16,983
    521
    Las Vegas, NV
    This would interface with the clamshell motor mount B26EC8E3-FAF3-4B56-BC4A-D8841D4F9466.png
  6. CaliCamaro75
    415
    24
    Sep 6, 2015
    Winchester,CA
    So LS plates - engine mount bracket - to clam shell?
  7. Lars_2Gen
    Lars_2Gen Veteran Member
    629
    158
    Dec 29, 2017
    Fullerton, CA
    No, those are the wrong engine mounts... should be: LS mount - clamshell - then there should be a motor mount captured in a bracket attached to the frame (top left in Badazz's pic).
  8. CaliCamaro75
    415
    24
    Sep 6, 2015
    Winchester,CA
    LARS you lost me
    The top left is a clam shell. Unless I'm mistaken.
    Frame to motor? Clams will get the poly inserts
  9. badazz81z28
    16,983
    521
    Las Vegas, NV
    Pic one goes on the frame, pic 2 bolts to the brackets in pic 3, of course pic 3 bolts to the block.
  10. Lars_2Gen
    629
    158
    Dec 29, 2017
    Fullerton, CA
    Exactly.
