Leaf spring front bushing install
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Greg Mc, Jan 19, 2020.
  1. Greg Mc
    Greg Mc Veteran Member
    1,211
    Mar 18, 1999
    Hernando, MS
    I am replacing the front bushings in my leaf springs with Moog rubber bushings. I think the factory springs have the bushings pushed in from the same direction and I've heard new replacement springs are the same. Is there any advantage or improvement to installing the bushing one way for the left side and the other way for the right. Does it ensure better axle centering by installing each side differently. Did a search and really didn't find definitive answer.
  2. badazz81z28
    17,382
    604
    Alabama
    The last couple of times I bought new springs, they were the same both sides. I’m OCD, if I was pressing them in, I would have them mirrored image.
  3. berg2695
    berg2695 Veteran Member
    295
    59
    Nov 13, 2011
    AUBURN, WA
    I agree with Badazz. I recommend installing both bushings so that they go in from the inboard side of the spring. That way, when the car is cornering, the body is leaning on the 'meatier' side of the bushing for slightly less deflection. It may not even be measurable, but these are the kinds of things I waste my time thinking about. o_O
    cadillac_al and dave@ztech like this.
  4. Greg Mc
    1,211
    Mar 18, 1999
    Hernando, MS
    Thanks......I think that is what I will do. I think too much about this kind of stuff too, it just seems the right way to install the bushings to me.
