Leaf-Spring Misalignment
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 71smalbloc, Sep 5, 2019.
  1. 71smalbloc
    71smalbloc Member
    55
    Jan 6, 2016
    Blacksburg, VA
    I went ahead and removed the old slapper bars and replaced the leaf springs on my 71 today. Biggest issue I'm having is that the center pin/bolt on the passenger leaf spring does not line up with the center hole in the anchor plate. This of course doesn't allow the anchor plate to sit flush with the axle. I attached a photo of the driver side which lines up decently enough to get an idea of what I'm talking about.
    The springs, anchor plate, and hardware are all brand new and center hole in the anchor plate appears to be correctly centered. The car does have a set of longer shackles which I'm thinking may be contributing to the issue. What do you guys think?
  2. badazz81z28
    16,588
    438
    Las Vegas, NV
    Loosen it all up and adjust it (both sides). You don’t need long shackles in the back.
  3. Jeep43
    Jeep43 Veteran Member
    1,282
    45
    Mar 30, 1999
    Connecticut
    If you think its the shackles, loosen the bolts and clamp down the plates on center, then tighten the shackle bolts.
  4. Fbird
    3,868
    596
    Feb 12, 2011
    atlanta, ga
    BFH.....alignment tool...shackles should have minimal affect there. More likely the top pad allowed the "bolt" to squish into to wrong location..
