Leaking Brakes - all new components
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Lars_2Gen, Nov 11, 2019.
  1. dale68z
    dale68z Veteran Member
    1,364
    22
    May 14, 2009
    Glendale Arizona
    What do you have the banjo bolts torqued to? They need to be tighter than you think. Torque to 30, if it still leaks, torque to 35' pounds. Not sure what the grade a banjo is but I suspect grade 5.
  2. 70-camaro
    70-camaro Veteran Member
    2,402
    445
    Mar 25, 2010
    marietta ohio
    You may also need to reflare the rear lines.
  3. Lars_2Gen
    Lars_2Gen Veteran Member
    628
    156
    Dec 29, 2017
    Fullerton, CA
    I cranked on the banjos pretty good but didn't use a torque wrench. I'll torque them tomorrow
    For three rears I'm going to try the "Right Stuff" hose to match the hard lines. Maybe that will help.
  4. wasp
    wasp Member
    79
    Mar 8, 2009
    Milpitas, CA
    Loosen the flared fittings and then tighten them again. This helps to create a good seal on new lines.You may need to do this several times. If this does not work try a conical seal. Just google search flare fitting washers. Summit racing sells them.
  5. Jeep43
    Jeep43 Veteran Member
    1,305
    48
    Mar 30, 1999
    Connecticut
    Stainless hard lines?
  6. ol' grouch
    ol' grouch Veteran Member
    2,999
    835
    Jul 4, 2013
    Evansville, In.
    You did remove the old copper washers and use brand new ones didn't you? Old ones will take a set and new lines may not seal on them.
  7. Lars_2Gen
    628
    156
    Dec 29, 2017
    Fullerton, CA
    Headlines are replacement, not stainless.
    Yes of course I used new copper washers... not my 1st rodeo.
  8. badazz81z28
    16,972
    512
    Las Vegas, NV
    You really need to use a torque wrench (At least I do). The banjo bolt doesn’t really need to be any tighter than 15-25ftlbs. If they leak, you could have the improper copper washers that are not soft or there is a defect on the sealing surfaces. I have never had an issue with a banjo sealing. The flares however are particular. They need to be perfect and in many cases the flare is cracked or flared crooked. If you wrench in it really good and it still leaks, chances are even tighter isn’t going to seal. I now use NiCOP. It’s much more forgiving and seals the first time, every time.
