LED replacement Dome light/interior light question
Discussion in 'Electrical Systems' started by rocket dawg, Aug 10, 2019.
  1. rocket dawg
    rocket dawg Veteran Member
    334
    28
    May 5, 2015
    Grand Rapids Mi
    Since the interior is just about done, I have a burnt 561 dome light bulb that still works but I can see it's discolored as in it must have got hot. Are the LED's cooler temp wise? Brightness better? worse? Are the floor lights worth replacing as well? thanks
  2. Twisted_Metal
    27,056
    996
    LEDs are Much cooler.
    Try taking a dome light bulb loose from the socket when it’s lit up... The smoke from your fingertips will give you a clue just how hot they get! :eek:
    Yup... I did that. ONCE!
    There are too many choices for interior LED lighting to even try to suggest the “best” ones.
    Browse eBay for compatible bulbs and go with what you like for color, design and cost.
    I found 36 SMD LED panel which fits inside the dome light lens. ($5 on eBay)
    It’s bright enough that you don’t need lights under the dash.
    rocket dawg likes this.
  3. rocket dawg
    334
    28
    May 5, 2015
    Grand Rapids Mi
  4. Twisted_Metal
    27,056
    996
  5. grzewnicki
    3,425
    158
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I think I used the 36 LED one, it is awesome, you can actually see stuff! Cheap too, think I bought mine off E-Bay also. Probably the cheapest thing I bought that made that big of a difference. Mine is bright white light, works great with black interior. No need for sunglasses when you turn it on....
  6. 70 Proof
    70 Proof Veteran Member
    546
    56
    Sep 28, 2014
    Southern Utah
    Mine LED's work great in both the dome light and rear console light (bought at Amazon). as an added benefit LED's draw fewer amps than incandescent lights.
  7. rocket dawg
    334
    28
    May 5, 2015
    Grand Rapids Mi
    The interior is now charcoal carpet with black seats, so maybe the 36 style one. For the price, I'll probably order the 20 and the 36. Thanks. Finished phase one of the interior yesterday, floor repair- sound deadening- speaker shelf-speakers-stereo- headliner- carpet- console- seats--kick panels- painted dash and steering column--$$$$$. it looks great, pictures to follow in the right forum section. Today I'm chasing a vibration from behind the stereo, Its more than likely a loose radio support as I had trouble getting it tight.
  8. grzewnicki
    3,425
    158
    Dec 9, 2009
    Aaaah, never thought about the rear console one, great idea!
