Let's talk fuel pumps
Discussion in 'High Performance Modifications' started by muscl car, Jan 4, 2019.
  1. muscl car
    21,492
    551
    Jul 8, 2001
    High Desert of Hesperia Calif
    Next on the upgrade list and able to support the new 600 plus hp 406sbc is a fuel pump . Currently running on my old motor is Carter "strip " mech fuel pump set at 7psi
    Now I'm looking at either a new in tank fuel pump set up or just a good race style electric fuel pump mounted to the chassis or body . The Camaro does have NHRA Certified aluminum Trunk bulkhead so I could mount a fuel cell in the trunk
    1980RS likes this.
  2. SRGN
    SRGN Veteran Member
    651
    208
    Feb 20, 2009
    Central NJ
    If more race than street, fuel cell with a quality electric pump gets my vote. I have had very good luck with Fuelab and Aeromotive, running race fuel and no ethanol. I did run E10 pump gas with an Aeromotive pump a few times without issue. Holley has come out with some new pumps, but I don't have any experience with them. On paper, they look good, I just have no reason to change since I have a pump capable of supporting the power I will make.
  3. Zspoiler
    Zspoiler Veteran Member
    3,118
    236
    May 6, 2012
    Federal Way, Washington
    Its all personal preference .You can run an electric fuel or a high volume mechanical pump, I would run half inch line with either type.
  4. camaro71/holland
    1,178
    66
    Aug 27, 2003
    The Netherlands
    Might be overkill, but for straight line performance without fuel starvation you could also leave the mech pump, connect it to a small 0.5L or so tank up front fed by an electrical pump in the back. This way both pumps don't have to be large and work hard and won't run out of fuel as well. Buddy has a similar setup op a 401 with a 177 blower on top.
  5. xten
    xten Veteran Member
    2,555
    1,375
    Sep 24, 2014
    Pittsburgh, Pa.
    Some race pumps don't like the street. I think Aeromotive is good for a mix of street/strip. I have had an A 1000 for years. Never a problem. Kid runs two of them with E-85, and they've been great. They have a new pump out, but don't have any reason (yet) to research. Run a relay with an electric pump. Makes a difference.
  6. 77 cruiser
    77 cruiser Veteran Member
    530
    23
    Nov 17, 2006
    Frostbite Falls MN
    In tank electric, with a return regulator.
  7. 1980RS
    1980RS Veteran Member
    3,013
    448
    Jun 17, 2006
    MN
    Been running the same Mallory comp 140 since 1992 on the Camaro and a 8 gal fuel cell, also have one for the NOS stand alone.
  8. 79RedZ
    79RedZ Veteran Member
    676
    35
    Mar 24, 2009
    Hamilton,MI
    ^^^^ I've been running the Mallory 140 myself since 2005. It is a bit noisy but I haven't had any problems.
  9. muscl car
    21,492
    551
    Jul 8, 2001
    Looks like I'm going with a 12 gal Jaz racing fuel cell and Magnafuel 275 fuel pump
  10. RS1979
    3,652
    689
    Jun 18, 2013
    Memphis, TN
    This is really for your Tacoma isn't it. C'mon admit it. lol
