Looking for some door hinge parts
Discussion in 'Swap Meet Section' started by 78LT383, Jul 10, 2013.
  1. 78LT383
    78LT383 Veteran Member Lifetime Gold Member
    1,779
    Jul 12, 2005
    Princeville, IL USA
    Hey guys,
    Got any damaged door hinges? I need a few parts off of a set or two of them. The main thin I need is one or two of the roller wheels. These things are hardened, so a bent hinge, one from a collision, or worn out beyond repair would probably even work. I don't ultimately need the whole hinge, but if that's what is laying around and you don't want to take them apart I can do it.
    I'm on a shoestring budget but can gladly pay shipping and a few bucks for even a completely worn out hinge or two.
  2. Ryan 79
    Ryan 79 Veteran Member Lifetime Gold Member
    3,299
    Mar 29, 1999
    Granite Falls, WA
    You can order new 4th gen rollers and roller pins from GM Parts Direct. They have the same pin size and are the same diameter as originals, and youll get them for less than you would pay for having a couple of hinges shipped to you
    Or....
    I could rebuild you a complete set of hinges(all four) for 180 shipped
  3. 78LT383
    1,779
    Jul 12, 2005
    Princeville, IL USA
    Oh, great! Thank you!
    What all is done to your rebuilt hinges? Do you upgrade them so that they won't wear out like the originals?
  4. Ryan 79
    3,299
    Mar 29, 1999
    Granite Falls, WA
    I weld up the stretched holes back to original size, strip and paint, new pins and bushings and new rollers
