Looking for stock height spindles
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Rider1970, Aug 13, 2018.
  1. Rider1970
    Rider1970 Veteran Member
    125
    Jan 20, 2017
    Michigan
    Looking for stock height spindles. The idiot that I bought my car from let the wheel bearings eat into the spindles. I need to get new ones but all I am finding are drop spindles, cant find stock height spindles anywhere. Does anyone have a link to to new spindles? I dont want anything used/re manufactured. Thanks for your help.
  2. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
  3. BonzoHansen
    19,494
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    No, those are 1st gen parts.
    Used 2nd gen spindles are easy to find. There are only 2 variants the early ones and the very late ones that use a different outer bearing. I forget the year of the change maybe 1980. You can use either one but you have to use the right rotors and bearings.
    And then another option are the B body spindles which can give you a 12" rotor if you buy the right ones. But that's another discussion.
    Rider1970 likes this.
  4. Rider1970
    125
    Jan 20, 2017
    Michigan
    Yep need 2nd gen spindles. This is for a 70. The reason I don't need drop spindles is I already have adjustable height springs and shocks.
  5. 79T/Aman
    2,544
    177
    Oct 7, 2004
    Dickson TN.
    no one makes new 2nd gen spindles, gonna need to find used ones , should not be that hard to find.
  6. Rider1970
    125
    Jan 20, 2017
    Michigan
    I can find new 2" drop spindles, will that work with adjustable coilover QA1 shocks and springs? Im running 245/40/17 on the front and dont want the tires to rub but I want to bring it down from the stock height.
  7. hogg
    hogg Veteran Member
    3,168
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    the 70- 74 maybe , the spindles are different, all can be used only make sure you get the full set,both sides.
  8. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
  9. dave@ztech
    3,508
    718
    Mar 27, 2016
    NY
  10. 79T/Aman
    2,544
    177
    Oct 7, 2004
    Dickson TN.
    what year is your car? 70-78 use A6 inner bearings , A2 outer bearings the 70-74 look different but it's only looks.
    79-81 use A6 inner and A3 outer bearings
