Lost a couple lobes after oil change.
Discussion in 'Engine Topic' started by Craig69SSRS, Sep 19, 2019.
  1. CorkyE
    10,201
    414
    How so, catalytic converter?
  2. COPO
    17,621
    649
    No. We have no cats on these cars. It’ll do harm to the metal your trying to protect in the engine.
  3. CorkyE
    10,201
    414
    Was fishing with the question, but only reason I can see is that way too much zinc can sludge up an engine.
  4. COPO
    17,621
    649
    I dought sludge is the issue. With too much ZDDP you will see corrosive wear and the oil becoming acidic.
    76z28 likes this.
  5. 76z28
    76z28 Veteran Member
    1,982
    42
    Jun 29, 2009
    bakersfield
    Copo is correct and if will also inhibit grain structure of certain metal contact areas
  6. roadrace2
    roadrace2 Veteran Member
    1,658
    35
    Jan 13, 2000
    Earth......?
    Great discussion! (my 2 cents) :D
  7. 80NastyZ
    80NastyZ Veteran Member
    163
    Feb 8, 2007
    Poconos P.A.
    To the OP :
    Was the oil filter bypass plugged ? Or was the OE valve still in place ?
    And I will second what 76z28 has stated , oil is not the issue with SFT or HFT cams going flat , there are many issues that contribute , oil is a very small part of it , especially in a BBC .
    At the 5K miles the OP said was on the engine , those lobes were "going" flat for almost all of that mileage , it didn't happen all of a sudden. That's a fact.
    TOM
  8. COPO
    17,621
    649
    If while breaking in a cam and your pushrods are not rotating, then the cam will be toast sooner or later.
  9. 80NastyZ
    163
    Feb 8, 2007
    Poconos P.A.
    As well as the lifters ......
    I would wager a bet that those whom have "lost" flat tappet cams (and even those that have not) could not begin to tell anyone what the lifter bore clearance is .
    As these parts wear , holes that were once round , are not .
    TOM
  10. Bandit723
    Bandit723 Veteran Member
    3,145
    462
    Oct 1, 2016
    Waupaca WI
    ^^^ Novel Idea.....
