Lot of Pressure at the gas Cap
Discussion in '1970 - 1973 Specific' started by aztec, Mar 15, 2012.
  1. aztec
    aztec New Member
    17
    Feb 8, 2012
    pacific north west
    Hello I got a 1971 camaro removed all the canister hose on the gas tank and pluged all the lines switch over to a vented cap from a 70 so i wil be able to vent but every time i remove the cap it want to fly out is this normal
    or is there some thing els I need to do I dont want to use any of the emisions crap it had on it just all clutter and were all old and rusted Need Help on what i should be doing thanks
  2. High Country Z
    High Country Z Veteran Member
    Last time I checked, a '70 gas cap won't fit a '71 gas tank neck.
  3. aztec
    aztec New Member
    17
    Feb 8, 2012
    pacific north west
    Thats what they told me at the napa parts store that it was for a 1970 it says (vented/ anti surge) on it
  4. High Country Z
    Do you have the part number?
  5. COPO
    15,449
    88
    Toronto
    Shake the cap and if it's vented, you can hear the check ball rattle inside. It sounds like the cap is not vented if your getting a whoooosh of air shooting out or the ball is not loose.
  6. aztec
    aztec New Member
    17
    Feb 8, 2012
    pacific north west
    3931449 is what they crossed refrenced it to
  7. aztec
    aztec New Member
    17
    Feb 8, 2012
    pacific north west
    there is some type of ball or something because it does have some play
    but like i said it says vented anti slug right on it
  8. aztec
    aztec New Member
    17
    Feb 8, 2012
    pacific north west
    is there another way to vent it not using that cap??
  9. krabben1
    8,073
    May 16, 2007
    ( . Y . )Delco
    I connected all the vent line tubes from the tank with gas safe plastic tees,and put a rear differential vent at the end.
  10. COPO
    15,449
    88
    Toronto
    I have a vented locking gas cap that did not vent properly when I bought it. I took it apart and the pressure relief hole was not fully stamped open. Once that was fixed it vented properly.
