LQ4 heads, cast iron vs. aluminum
Discussion in 'High Tech Retrofits' started by Paul1979, Sep 12, 2011.
  1. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    What will the motor be used for though? The cathedral port heads will pretty easily support 500hp, so the extra cost of going to the rectangle port heads (which also means a new intake manifold, which ain't cheap) may not really pay off if the cathedral port heads can support the power he wants to make.
  2. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    Not bad advice, but just remember that will also require a new intake manifold, fuel rails and fuel injectors. The intake manifold will then require a bigger throttle body (aftermarket as all OE are drive-by-wire) which is then often combined with a new MAF and intake plumbing.
    I'm considering this upgrade from my LS2 with ported 243 heads, but the price is so high I am considering just buying an entire used LS3 engine.
    As always, these decisions depend upon your budget and expectations. If you are on a budget, I would still suggest aluminum heads. In a few years LS3/L92 parts should be more affordable. Just my 2 or 3 cents.
  3. mrvedit
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    Funny how Air Adam and I posted the same thing 40 seconds apart. This is a great forum with lots of activity and fast replies.
  4. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    In the end, it all does depend on what the OP wants out of his car.
    He never specified if this was going to be carb'd or factory FI yet.
    I see spending $200 on exact same performance as a waste.
    The only thing he's saving is weight......
    For that amount it's not really noticeable on a cruiser IMO.
    Corner carving autocross or road race car, absolutely I'd consider it.
    Stock 317 heads flow.
    http://ls1tech.com/forums/10332813-post7.html
    Stock L92 heads flow.
    http://ls1tech.com/forums/4564757-post1.html
  5. Air_Adam
    2,927
    Feb 7, 2004
  6. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    222
    Sep 22, 2007
    Long Island, New York
    What is the difference between 243 and 5364 cylinder heads?
  7. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
  8. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    All the Gen III's with the exception of the 4.8L , used the same stroke crankshaft.
  9. griffsbombelco
    220
    Aug 17, 2009
    socal
    It's not the stroke that's diff it's the flange the flex plate bolts to that's diff only used on all early steel headed 6.0s
  10. Camaro-Chevelle
    222
    Sep 22, 2007
    I purchased a LY6 and 4L80 out of a 2009 Chevy Van. It comes complete with the wiring harness, TCM and all accessories. I am curious to see how good the cylinder heads are. Then I can make a decision on whether I need to upgrade the cylinder heads or not.
