LQ4 heads, cast iron vs. aluminum
Discussion in 'High Tech Retrofits' started by Paul1979, Sep 12, 2011.
  1. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    222
    Sep 22, 2007
    Long Island, New York
    I have another question. What are 823 castings?
  2. 79cam6.0
    79cam6.0 Veteran Member
    207
    Jan 24, 2013
    Conway, AR
  3. 79cam6.0
    207
    Jan 24, 2013
    Conway, AR
    that shows the difference between the iron head engine and aluminum
  4. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Rect L92 heads
  5. 79cam6.0
    207
    Jan 24, 2013
    Conway, AR
    and the early 6.0 uses the long crankshaft that does not use a crank spacer. you can not run a 99+ 4l60e behind one of those. it will work with any older trans and 4l80e.
  6. Camaro-Chevelle
    222
    Sep 22, 2007
    Are the 5364 cylinder heads aluminum rectangular port heads? How are they different from the 823 cylinder heads?
  7. Camaro-Chevelle
    222
    Sep 22, 2007
  8. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    IMO, I would pay the extra $200 for the aluminum headed version.
    If you're not getting a killer deal on this engine though and it might need a rebuild, I would look into a newer L92 with low miles. Probably cheaper in the long run! (ask me how I know)
  9. Camaro-Chevelle
    222
    Sep 22, 2007
    I purchased a LY6 and 4L80 out of a 2009 2500 Van with 20,000 miles on it. The setup is complete with the TCM, wiring and all accessories. The motor has aluminum 823 rectangular port heads. I also purchased the LY6SS camshaft from Mast Motorsports. This should be a great combo. I will keep everyone posted.
