LS Adventure Begins
Discussion in 'High Tech Retrofits' started by JJFarmer, Dec 23, 2009.
  1. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    One of these days Gordo....one of these days, lol.
    I was looking at the alt and I though it might hit. So which one do I need or should I move it up high like the Vette mounting...above the PS pump?
    I didn't know that this had the LS6 shortblock and intake already..WOOT. SO looking at the cam swap...now if I could find some cheap LS6 heads, or better.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    It will hit your pittman arm. Mine did. I have the same engine in my car.
    I called Speed and Performance for an alt relocation kit and it was $550.
    So you don't want to call them. My car was just in a shop with the boys
    doing the install and I didn't have many options or time back in 2006.
    Some one posted some OTHER options, I believe it was Knuckle Dragger recently.....
    Here's where mine is, and yes, I tossed the A/C stuff too.
  3. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    I have to move the AC up on the pass side, so I'll need to raise the alt on the drivers side or figure out the mount for a low mount on the drivers side
  4. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Just an update...
    • Modified harness ships back tomorrow
    • PCM reprogrammed and ready
    • Fuel pump and part of fuel lines here
    • motor mounts here
    • new cam and 918 springs here
    • LS6 heads came in Friday
    • Oil pan and flywheel here (thanks Jake)
    Still needed...
    • headers (ouch)
    • Rest of fuel lines
    • head gaskets
    • settle on radiator (original vs GTO)
    • AC compressor
    • TIME
  5. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    What HP/lbs ft you shooting for ??
    Yeah headers aren't cheap....
  6. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Looking for around 425-450 rear wheel HP and easy to drive. Not a real big cam...224/228 @ 114lsa
  7. badazz81z28
    17,345
    596
    Alabama
    Wow! your asking alot!
    I just saw the new Camaro L99 motor on HPTV yesterday in which they installed a blower. It didnt make 450 at the wheels...close at 448hp...
    To get that much wheel hp out of your LS1, you need to produce over 550hp...
    I would like to hear if you make that goal or not.
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Looking around, I'm curious how you got the HP figures off that cam ??
    I'm looking and I see 345-400rwhp.....just curious if you verified this ??
    I was looking to swap cams too so I was just curious.
  9. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Just looking at what others have made with the same mods. Only the dyno knows what it'll make. Heck, it might not make 350...we'll see if I ever get it in.
  10. 77mouse_maro
    77mouse_maro Veteran Member
    128
    Sep 12, 2009
    Istanbul , TR
    if you swap it with a gt11 mild cam and patriot LS6 stage 2 heads , get some arp bolts and springs, it will preduce 400whp with a good drivetrain,
    any nos in the future? maybe 75 spray for fun?
