*Ls an fuel line fittings*what to use*
Discussion in 'High Tech Retrofits' started by 72BIGBLOCK, Jun 28, 2016.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,374
    83
    Feb 2, 2008
    SF
    Installing an fuel line fittings for the ls swap
    Should I use anything on them ?
    I know I shouldn't use Teflon tape so that's out of the question what can I use or what should I use ? A sealant? Which one ?
    The an fittings are new
    Thanks
  2. Goat
    1,905
    44
    Jun 7, 2001
    moncure, NC
    AN fittings do not require any sealant. They are compression type fittings...
  3. John Wright
    14,679
    208
    Aug 9, 2002
    Rustburg, Va
    AN fittings use a 37° tapered seat that seals the joint, so the threads don't actually see any fluid or need any sealant(provided the joint is snug-tightened).
  4. badazz81z28
    16,676
    462
    Las Vegas, NV
    If you're using hard line, take your time prepping the line and use a good flaring tool. I think loctite is the brand, but there is a sealant type liquid you can put on the sealing surfaces. It's suppose to fill in any small scratches or imperfections that would prevent a good seal
  5. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    Where would he need to flare the hard line? I thought AN style fittings like this one were simple compression style sittings?
  6. CorkyE
    10,306
    448
    These work well, I'm using them on my fuel lines.
  7. 72BIGBLOCK
    2,374
    83
    Feb 2, 2008
    SF
    I'm using an and 3/8 225 psi fuel line rubber not metal
  8. CorkyE
    10,306
    448
    Then Goat's initial response is correct, you do not use any type of sealant on AN fittings.
  9. 72BIGBLOCK
    2,374
    83
    Feb 2, 2008
    SF
    Got it
    Thanks everyone!!
    Hopefully this coming week we fire it up
  10. hot72rod
    2,993
    36
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    That's the same fitting I used, and as stated no flaring of the metal needed.
