**ls Engine With Carb?**
Discussion in 'High Tech Retrofits' started by 72BIGBLOCK, Oct 8, 2014.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,374
    83
    Feb 2, 2008
    SF
    hi everyone, so im looking to do an ls conversion but its easier to go with a carb set up. so I was thinking about an ls 327 crate engine that only needs a belt set up and a carb.
    anyone here running an ls with a carb?
    I was told an ls with a carb wont run as well as an ls with efi.
    so now im a confused any input?
    thanks
  2. 5spd540
    12,377
    16
    Sep 19, 2009
    Guyton, GA
    Use the EFI you wont be sorry. There are plenty of woring kits to help with this now days. Dont go carb you will have issues with hood clearence that you wont have with EFI
  3. 72BIGBLOCK
    2,374
    83
    Feb 2, 2008
    SF
    Its for my 69 camaro hmm... the install cost is around 2500the I guess your right though
  4. SupplySgt
    SupplySgt Veteran Member Lifetime Gold Member
    1,374
    Jun 20, 2009
    Finally back home!!!
    There are a fair amount of guys on here who have a Carb'd LS and they like it. I enjoy both. I enjoy the challenge of the carb in the 73 (most of my automotive experience deals with EFI so it's nice to play with something different) but I also like the EFI Vortec 350 in the 78.
  5. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    You can't go wrong either way as it's really just preference. I can say though that modern EFI is such a nice thing to have and once you have it, you will never go back to a carb. You run much more aggressive cams with EFI and not have to play with the settings like you will with a carb. All I'm saying is the little hassle and a few more dollars is worth the EFI.
