LS Header options
Discussion in 'High Tech Retrofits' started by flak monkey, Oct 26, 2015.
  1. badazz81z28
    17,358
    598
    Alabama
    Yup, you got to be mindful of that! I had that problem with dynatechs LS headers. The driver side floor pan required some massage to fit the O2. DSE headers were a miracle for me....even though they are $2k!
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    $2k for headers, DANG!!
  3. AlbertaZ28
    AlbertaZ28 Veteran Member
    259
    Aug 17, 2010
    Fort Mcmurray, Alberta
    Which side isn't fitting? Both of them? I finally got around to putting mine on and so far have the drivers side in and the O2 sensor fits perfect.
  4. AlbertaZ28
    259
    Aug 17, 2010
    Which spark plug wires did you go with? Speed Engineering recommends MSD. The stocks will obviously not work.
  5. badazz81z28
    17,358
    598
    Alabama
    Why not?
  6. AlbertaZ28
    259
    Aug 17, 2010
    The drivers side header is too tight on the front plug. The boot is right against the header. Apparently the MSD are able to be bent to fit.
  7. badazz81z28
    17,358
    598
    Alabama
    You'll need a DEI sleeve or similar. No plug wire will avoid a tube that's simply too close to the plug
  8. AlbertaZ28
    259
    Aug 17, 2010
    Those would probably do the trick and probably much cheaper than new wires. Thanks
  9. smoothyrogers
    smoothyrogers New Member
    9
    Jan 7, 2014
    miami,fl
    I have an ls3 in an 80. Speed engineering longtubes. Under 300 and they fit with no modifications.
  10. 1977nova
    1977nova Member
    50
    Jul 19, 2005
    canada
    Would you have any photos? How is the ground clearance?
