LS Header options
Discussion in 'High Tech Retrofits' started by flak monkey, Oct 26, 2015.
  1. smoothyrogers
    smoothyrogers New Member
    9
    Jan 7, 2014
    miami,fl
    Speed engineering
  2. 70RS_L48
    70RS_L48 Veteran Member
    386
    Mar 4, 2010
    Seattle Area
    I'm using the newer Hooker Blackheart headers with my DSE subframe, and the fit and finish is really amazing. I've got the steering column installed now and the steering shaft fit is excellent. They're about $1400 for full stainless. Not cheap, but good value.
  3. DB Z28
    DB Z28 Veteran Member
    568
    44
    Nov 30, 2003
    Fond Du Lac
    DSC_0553.JPG [​IMG]
    For hooker Header, Long tube 1/7/8 primary
    You will need - Clutch Pivot Ball Bracket for GM Cars and Trucks his to bolt on your bell housing might have to clearance the block and bellhousing . I had to do it with mine and space the bracket on the frame one inch out Im using the Hooker stainless long 1 7/8 tube and hooker mounts This is order to get a Manual clutch linkage to work
