Ls intake and exhaust questions.
Discussion in 'High Tech Retrofits' started by 408maro, Nov 26, 2016.
  1. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    Kind of a 2 part question...
    About ready to start my LS swap as I got what I think to be everything I need.. but will still need to figure out a intake system..
    What you'll using and where you getting the air from for the intake system?
    Also how about exhaust? right now I have borla and most likely will keep but curious what sounds good on these engines and want to using v band clamps
    Thanks
  2. TheMeat
    TheMeat Veteran Member
    963
    Feb 9, 2007
    Ol' Miss.
    Ive been using the truck intake.
    My 3xhaust is 4"stainless to a 4" hooker max flow muffler, all v bands.
    Id stick with the borla youve got and make it work. If you have a cowl hood, truck intake will work fine. If not, better swap to a car intake
  3. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Sorry meant from outside air into the tb of the intake..
    I think I may reuse the borla though.. I like them
  4. hot72rod
    I purchased aluminum pipe and couplings from a company on line called siliconeintakes.com. I ran my air supply to the drivers side.
    I plan on installing a cold air box that I have built. This will help keep the hot air from the engine bay out of the air charge. I also have a bird so the core support is a little different. You can't see it in the pic but there is a large hole from the factory just under that silver box on the drivers side.
  5. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    very nice... i may have to something similar
  6. badazz81z28
    14,185
    110
    Las Vegas, NV
    Spectre makes a ready to bolt on cold air intake. As for an intake, your choice but I wound seek out a low profile car intake
  7. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    I'm going to use the ls3 stock intake itself... and thanks for the post...I'll be using the driver side mounted kit from spectre 900134...
  8. CAMeeks
    CAMeeks Veteran Member
    502
    Jan 5, 2014
    Deer Park, TX
    If you put a "b" at the end of that part number in jegs (900134B) it drops the price $20
  9. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Awesome thanks!!! crazy $20 more for red?
  10. csjrishere
    csjrishere Veteran Member
    122
    Dec 7, 2010
    Pittsburgh, PA
    I tried to buy this item from Summit last week and just got an email last night saying the manufacturer told them that this item will no longer be available.
