Ls,(LM7) to my 79Z 4 speed,(Borg Warner T-10)
Discussion in 'High Tech Retrofits' started by Impact-mk, Feb 18, 2017.
  1. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    I know that i will have to change a few parts, but im not quite ready to try and convert to a 6 speed due to the hydraulic, so does anyone have any knowledge on how, what parts i will need to change, and any brand recommendations, or do's and do not's ?, also the question of weather it would be easier to mount up my 73's old Muncie, m-22? i would rather use the T-10 so i ca use the muncie in my 73,
  2. BonzoHansen
    19,443
    799
    Jun 1, 2005
    Scott from Hamilton, NJ
    A 4 speed is a 4 speed for what you are looking to do. There are guys who have done it. I think there is a bracket out there that lets you keep your z bar.
  3. CasperCasper
    CasperCasper Veteran Member
    1,071
    176
    Aug 11, 2015
    Its not rocket science. I have the dirtiest rat out there. Long crank 99 6l, mcleod flywheel, mcleod sm465 bellhousing with bore adapter ring and a super t10. You can use a bbc bellhousing, ls flywheel and correct throwout bearing. Do some looking around ls1tech, there is a sticky on doing this. Long story short use a BBC bellhousing and the appropriate throwout (cant remember which) and go. You will need to telocate the holes on your crossmember, theyre an inch or so off. Use the stock trans mount. Cheers
    Impact-mk likes this.
  4. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Thank you, this is the info i was looking for, do the mcleod parts work well?
  5. BonzoHansen
    19,443
    799
    Jun 1, 2005
    Whats a bbc bellhousing? Is it different from a sbc bellhousing?
  6. CasperCasper
    1,071
    176
    Aug 11, 2015
    Bbc = big block chevy
    Mcleod also does an ls1 to muncie bellhousing. Email mcleod with any questions they can help.
  7. badazz81z28
    16,979
    518
    Las Vegas, NV
    Hydraulic is actually an easier set-up then mechanical. Much less parts to deal with.
  8. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    i know hydraulic is fairly easy but i don't really want to do the fab work, and through all the looking i have done locally and even within about 1000km i haven't found a suitable trans or parts car where things are intact enough to loot the hydraulic parts, within my price range that is, same going for after market conversions for the most part, i was quite happily surprised by the price of the conversion on McLeod's web page,
    Your "Dirty Rat'' is looking really good,
    Both of you gentleman's Cars are looking marvelous,
  9. BonzoHansen
    19,443
    799
    Jun 1, 2005
    I mean what is a bbc bellhousing? I did not know they were different from sbc bells. What numbers are bbc bells?
  10. CasperCasper
    1,071
    176
    Aug 11, 2015
    It is just a 168 tooth bell with the small locating bore. 621 is the number
