Ls,(LM7) to my 79Z 4 speed,(Borg Warner T-10)
Discussion in 'High Tech Retrofits' started by Impact-mk, Feb 18, 2017.
  1. czizza
    czizza Veteran Member
    986
    47
    Jan 8, 2004
    N. Massapequa, NY, USA
    I did the auto to conversion from a TH350 to a Super T10 which couldn't hold my power to a TKO500. I probably would have saved money if I would have went direct to the TKO, I had to rebuild the Super T10 3x before I found the TKO.
    Parts for the T10 and the TKO that are the same:
    1) Z-Bar setup for clutch
    2) Adjusting Pin for Z-Bar
    3) Springs for Z-Bar
    4) Clutch pedal
    5) Bellhousing (I used 621 at first)
    6) 168 tooth flywheel
    7) Ram clutch (nuked it on my first run, now using DFX from Centerforce)
    8) Bronze Pilot Bearing
    9) 4 Speed tunnel adapter (http://www.nastyz28.com/ubb/Forum12/HTML/007398.html)
    Now once this is all installed you can mate the trans to your car.
    For the back half (Super T10):
    1) Turbo 400 yoke
    2) If you don't have a TH350 you need a TH350 crossmember
    For the back half (TKO 500/600):
    1) TKO Yoke
    2) Shorten the drive shaft
    3) TKO crossmember (I got mine from SST former Keisler engineering).
    There might be more but you get the drift. Also, as you can see there is not much more work for the 5speed vs the 4speed.
  2. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Yes, but my car already has the T-10, and i plan on mating it to a newer T-56 magnum, before any real mods go into the car, i don't plan on anymore then 300-350 hp before the conversion to the T-56, So when you mated the T-10 were you running an LS? if so do you happen to have the part numbers for the pilot bearing, clutch, and where you got the proper flywheel?
  3. czizza
    986
    47
    Jan 8, 2004
    Sorry I am using a traditional small block ... also there are numerous threads on the T56 install ... you cannot use the manual clutch you will have to go hydraulic. From what my old brain can remember :)
  4. CasperCasper
    CasperCasper Veteran Member
    1,046
    147
    Aug 11, 2015
  5. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Yes but being able to afford a nice one is a ways off, and yes you do need to go hydraulic,
    Thank you!
  6. allstar12316
    allstar12316 Veteran Member
    248
    Dec 6, 2011
    Manalapan, Nj
    I am trying to do the same thing. I'm swapping a 5.3 but still reusing my t-10. Im trying to figure out what motor mounts I need to use. I have been looking at the Holley mounts, but don't know what depth I need, or if I should buy the mounts, or the plates. Help would be appreciated by the both of us I'm sure
  7. BonzoHansen
    19,302
    703
    Jun 1, 2005
    Scott from Hamilton, NJ
    You don't need to go hydraulic if you are using a SBC
  8. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    I am just using the "HOOKER 12618HKR - LS ENGINE SWAP MOUNT KIT", im getting it from TDot Performance but that is because its got Canadian shipping, but im sure the part number isn't going to change for other places haha,
  9. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    on the T56 you do because they aren't compatible with Manuel linkage, z-Bar and the likes, i believe,
  10. BonzoHansen
    19,302
    703
    Jun 1, 2005
    You better tell my car the clutch shouldn't work because it seems just fine with it :) lol
