Ls,(LM7) to my 79Z 4 speed,(Borg Warner T-10)
Discussion in 'High Tech Retrofits' started by Impact-mk, Feb 18, 2017.
  1. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Is it because you use a special bell housing/adapter plate? or is it one of D&D's special T56's?
    Im not trying to be a smart ass or rude, im just genuinely curious because most of what i have read says it needs or is designed to be used by a hydraulic throw out bearing, and the words.
    • Works with hydraulic clutch mechanism only
    have appeared a few times, now that said most of my checking has been for the T56 magnum,
  2. BonzoHansen
    19,285
    692
    Jun 1, 2005
    Scott from Hamilton, NJ
    I use a t56 out of a 4th gen and the stock 77 bell and clutch setup. I did it like 7 years ago, using a mcleod adapter plate. Since then quicktime started producing a bell with manual linakage.
  3. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Okay awesome, Does it work well? do you think that it is worth it to keep it manual clutch? just curious because i checked out your car and i think its wicked,
  4. BonzoHansen
    19,285
    692
    Jun 1, 2005
    Impact-mk likes this.
  5. BonzoHansen
    19,285
    692
    Jun 1, 2005
    Sorry, I missed this. It works perfect. I already had it all in the car nearly new when the T56 fell in my lap. So for me it was a cost savings not having to replace anything. I like mechanical but lots of guys like hydraulic. either way is fine.
  6. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    Wow that's awesome! and fairly inexpensive, thanks for sharing the find and remembering us "loons" haha,
    its perfect, the last piece of the puzzle before i can put the LQ9 into my car,
  7. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    So an update, i found a nice LQ9 with less then 150 k km (90 thousand miles) on it, i have gotten myself a bellhousing from my 81 big Doolly by grabbing a Nv 4500 from my 97 Gmc to replace it, i ordered an appropriate pilot bearing, and i am now trying to decide on a clutch, any suggestions? also i am thinking of using "HOOKER 12618HKR - LS ENGINE SWAP MOUNT KIT" for motor mounts, does any body have any opinions on these mounts?
  8. CasperCasper
    CasperCasper Veteran Member
    1,044
    144
    Aug 11, 2015
    I have those hooker mounts with my ls /st10 setup. I had to redrill the mount holes in my x member and thats it. They worked perf
  9. Impact-mk
    Impact-mk Member
    49
    Mar 25, 2015
    Sherwood park, Ab
    do you think that mine will need re-drilling? will all brands require it? thank you for your candor over the parts,
  10. CasperCasper
    1,044
    144
    Aug 11, 2015
    Ya it will but its not a big deal. You will need to space your trans off the bellhousong to fit a hydraulic throw out bearing and will thus need an extended pilot bearing.
