LS LQ4 Truck engine in 2nd gen
Discussion in 'High Tech Retrofits' started by f-body, Feb 16, 2008.
  1. dcart1
    dcart1 Veteran Member
    407
    Jan 22, 2009
    springfield,ohio
    I think if you use an oil pan from a blazer SS, it will work with no mods.
  2. Camaro_73
    Camaro_73 Veteran Member
    445
    20
    Mar 10, 2014
    Belton,TX
    QUOTE=Due North]Any clearance issues with the truck PS pump? I am strongly leaning towards the ICT setup so it's good to hear it fits. Any pics of the engine bay you could share?[/QUOTE]
    This is not my Camaro but its the exact kit I have that I was going to use in my 78, I think this is a 70-73 so basically the same thing. I'm in a group on Facebook called "lsx powered 2nd gen F-bodies" its a good group with good info.
    This is what he said about it.
    "Finally had time to install the pulley on my PS pump and throw the serpentine belt on it.I also 'massaged' the stock 1980 Camaro power steering pressure line to run from the steering box and pump (relocated using the ICT Billet 'truck' bracket kit).The return line is a different story so I'm just going to make one to fit"
  3. Mike N
    2,777
    546
    Jan 13, 2002
    Spencerport, NY.
    Not much belt touching the crank pulley in those pics, are you concerned with belt slippage?
  4. Camaro_73
    445
    20
    Mar 10, 2014
    Belton,TX
    Never thought about it once I saw the pics but I won't know till I'm using mine. But they do sell the same kit with a tensioner that sit in between the PS pump and crank which puts more belt running on the crank pulley.
  5. kttrucks
    kttrucks Member
    61
    Jan 13, 2014
    Nashville TN
    Got the LQ4 in my 78. I went straight to Holley for mounts and pan, as well as accessory drive. Their " long" drdive brackets worked great with my truck motor, and since I got my long block with ( only) the water pump, it works great with their accessory drive system. I know it's not salvage stuff, but it's basically Corvette based, and one could buy there brackets and spacers ( I think...) and use salvage drive brackets.... I dodnt want ot spend $$ on a new ballancer, and all the stuff lines up and fits great... there's something to be said for having it fit right out of the box. Check out there options... nice stuff.
  6. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    222
    Sep 22, 2007
    Long Island, New York
    For anyone interested, these are the parts that I used for the short Corvette Water Pump configuration:
    Water Pump ~ AC Delco 251-726
    Power Steering Pump ~ AutoZone 63106
    Power Steering Reservoir Kit ~ Holley 198-200
    Power Steering Pulley ~ Chevrolet Performance 12568997
    Driver Side Bracket Kit for Alternator and Power Steering Pump ~ Holley 20-135
    Accessory Drive Bracket Kit for SD508 A/C Compressor ~ Holley 20-132
    Harmonic Balancer ~ ATI Super Damper 917266
    I was able to use the truck alternator that came with the 6.0.
  7. Tpichevy
    Tpichevy Veteran Member
    504
    16
    Jun 21, 2016
    Boise id
    Subbed for this swap! trying to gather a cost of parts.
