LS swap 5.3 or 6.0 ?
Discussion in 'High Tech Retrofits' started by stroked383, Dec 6, 2012.
  1. stroked383
    stroked383 Veteran Member Lifetime Gold Member
    764
    Jul 18, 2011
    Saugerties, NY
    For those that are running LS engines, what are you running and why did you decide on that engine? I don't know the difference between all the different designations, ie LS2, LS6, LQ4 . I know the LS1 is an aluminum block 5.7L , other than that I'm not sure. I am trying to plan out my swap, any and all help and info is much appreciated.
  2. 70 gsconvt
    70 gsconvt Veteran Member
    1,095
    Sep 30, 2009
    Wadsworth, OH
    I don't have one......yet. But my opinion is, if you're going to go through all the trouble of an ls-series swap, why would you get a little one when you can get the bigger one for the same price that'll have better potential for power?
  3. lyrch
    lyrch Member
    65
    Jan 25, 2011
    west monroe la
    I went with the 6.0, although I'm not finished yet. The deciding factor was that I found a cheap wrecked 2001 suburban 2500.
  4. stroked383
    764
    Jul 18, 2011
    Saugerties, NY
    I feel the same way on the bigger displacement. I am pretty sure I am going with an iron block 6.0L. I just wan to see what opinions are out there to see if someone changes my mind. I'd love to go 6.2L but they don't seem to be real cheap.
  5. ryeguy2006a
    ryeguy2006a Veteran Member
    157
    Sep 29, 2009
    Upstate, NY
    Unless you can get a 6.0 for cheap, you might as well get an aluminum LS1. They are going to be around the same price as the 6.0, and you will save around 100 lbs. with the aluminum block. And the .3 liters won't make that much of a difference.
  6. stroked383
    764
    Jul 18, 2011
    Saugerties, NY
    I'm going twin turbo so I want the iron block for the strength.
  7. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    If your going turbo a 5.3 will be fine. All motor go 6.0 it's cheaper than a ls1 I got mine for 900 and can be found all day for 9-1300 the 6.0 has the bigger 4inch bore needed to run the bigger heads with the big valves
  8. griffsbombelco
    220
    Aug 17, 2009
    socal
    5.3= 3.78 bore ls1=3.89 6.0=4.00. L92 heads need a minimum 4.00 bore
  9. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    I you are going turbo, 5.3 will be good. They can and usually are bored to accept the 5.7 piston as there are many more choices in that diameter.
    I was originally looking for a 5.3 for my turbo build but, I found a deal on a LQ4 6 liter complete take out. Bigger turbo now needed!
  10. camarochevy1970
    camarochevy1970 Veteran Member
    7,750
    46
    Jan 23, 2003
    Pittsburgh, PA
    They do make an aluminum 6.0
    That said, my rule of thumb is to get the most displacement you can afford. They will all take boost, there is a large selection of aftermarket parts for all of them, and really you can't go wrong with any of them either
