Ls swap with truck accessories
Discussion in 'High Tech Retrofits' started by VandykeT/A, Jan 7, 2020.
  1. VandykeT/A
    VandykeT/A New Member
    11
    Feb 11, 2012
    Hurley, VA
    I’m LS swapping my 80 Trans am with shaker hood. I plan to go carb and I have a 5.3 truck engine ( 2 actually a 12 and a 03) both with accessories drives. Will either one of these fit under the stock hood? If not are there any aftermarket brackets that do drop the alternator enough to clear. I like the look of the aftermarket better anyway. Thanks.
  2. badazz81z28
    16,880
    496
    Las Vegas, NV
    There are places that sell alternator relocating kits. Take a look and compare your current drive
  3. hot72rod
    3,007
    36
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    Several place that sell a relocation brackets for the acc.
    depending on the frame mounts you use, may determined if you can use the truck brackets.
  4. Fbird
    4,039
    647
    Feb 12, 2011
    atlanta, ga
