Ls swapped...would you do it again?
Discussion in 'High Tech Retrofits' started by Fbird, Nov 25, 2019.
  1. Fbird
    4,051
    657
    Feb 12, 2011
    atlanta, ga
    After my keyboard research .... looks like about $3500 into a Ls motor gets me around the 400 hp mark then probably $2k for accessories (headers, mounts, etc....) Not sure how the LS computer stuff is going to like swapping out a cam in a 5.3 or 6.2? ...so from my initial info its a close one, staying PONCHO or abandoning the INDIAN for an Ls.
    Guess when I get to THAT moment i will have to decide.
  2. badazz81z28
    16,945
    505
    Las Vegas, NV
    You just gotta hunt down the deals. You can buy a GMPP accessory drive for $800. Significantly less used and even better if the engine has it. The best bang for the buck is the LS3. My modified LS1 had to work to keep up with a factory LS3. 430hp stock, add headers and better breathing and it will plenty of power.
  3. badazz81z28
    16,945
    505
    Las Vegas, NV
  4. muncie21
    muncie21 New Member
    10
    Jun 8, 2009
    NE, Ohio
    I put a LS1 and 4L60 trans in my'79 TA because I wanted the reliability of the FI motor. Still need to figure out a solution to get the speedo without going the GPS route and hooking up the rest of the gauges.
  5. mrfleet12
    mrfleet12 Veteran Member
    325
    91
    Aug 8, 2014
    West of Chicago IL
    You could give the guys a Hawks 3rd Gen a call, that's where I got my setup.. Basically an 05 GTO pull out LS2, I would agree with Badazz on the LS3 if you have the $$, if not and you want to get into the LS platform, the LS2 isn't a bad option..
  6. badazz81z28
    16,945
    505
    Las Vegas, NV
    I used complete auto meter gauges with an electric speedo. They do make adapters, haven’t seen them myself but people like American Power Train and Bowler would know.
  7. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    I wonder how the LT1 swap is, I would prefer it over the LS3, but would rather have an LS7... Maybe some day... You all make me want an LS. I like the idea of something 'easier' to work on. When I say easier, it is easier to get to stuff on the engine! I already have the fuel system, biggest cost would be headers and the actual engine for the LS.
  8. SPG
    SPG Bumblebee Builder
    369
    62
    Sep 1, 2018
    Sacramento
    this guy is putting an LT4 in his car, would more or less be the same aside from the super charger requiring a different belt system
    http://nastyz28.com/threads/79-z28-project-fast-times.325685/
    76z28 likes this.
  9. badazz81z28
    16,945
    505
    Las Vegas, NV
    I would want to do a LT4, but I don’t think it’s a easy swap yet. Still issues with the serpentine systems. I wouldn’t do a LT1, I rather stick with the LS3.
  10. 76z28
    2,051
    51
    Jun 29, 2009
    bakersfield
    Out of curiosity why?
    After driving both that lt1 is a monster down low compared to the ls3
