Ls swapped...would you do it again?
Discussion in 'High Tech Retrofits' started by Fbird, Nov 25, 2019.
  1. badazz81z28
    16,945
    505
    Las Vegas, NV
    A LT1 being a monster over the LS3? Maybe if the LT1 was in a lighter car. They have the same displacement and the only significant difference is the LT1 has a more aggressive cam. The performance is very comparable. Because of this I would buy an engine that had a larger aftermarket support. When more than than a couple options are available for things like drive accessories, intakes etc. I would gain more interest. However GDI engines are notorious for carbon build-up. Not sure if I want to deal with that. When it comes time for a new engine for me, I think I’ll stick to the large cubes of the LS
  2. 76z28
    76z28 Veteran Member
    2,051
    51
    Jun 29, 2009
    bakersfield
    It makes a lot more down low torque than the ls3 which makes it feel like a monster in comparison.
    It actually makes the same torque as the ls7 down low which is awesome out of a much smaller engine. I would agree the direct injection is something that would suck to deal with.
  3. badazz81z28
    16,945
    505
    Las Vegas, NV
    looks like Texas Speed can re-sleeve these to accommodate 427 ci too
  4. TCinthe6
    TCinthe6 Veteran Member
    127
    38
    Nov 5, 2017
    Toronto, Canada
    There is a certain charm when it comes to driving a carb'd big/small block. Idle nature is completely different when you compare the old school stuff to an LS platform, and I will admit that I miss the way my big block sounded sitting at a red light or in the drive way. But as mentioned by others, I turn the key, let it warm up for 30 seconds, and drive with 400+ hp at the wheel with a stock LS376/480.
    There are a bunch of ways to save a couple bucks on an LS swap. If you are ok with some of those compromises and the process to get you there, then go for it. Otherwise it is not a cheap endeavour. I dare not add up how much I have spent on my swap, but the lesson learned is that "chips build chunks". All the small things add up quick. But do it right, and there's no looking back.
  5. hot72rod
    3,013
    37
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    Would I do it again, yes.
    Cost out the difference in building a 400 Pontiac and picking up a LS2 or LS3 with trans.
    The 2k for accessories is about right depending on what you do and how you intend to use the car. You may actually be able to come in a little cheaper.
  6. bazookatooths
    bazookatooths New Member
    27
    Apr 25, 2018
    OKC OK
    I'm still working on my swap got it running a couple weeks ago. I'm surprised how beautiful this 5.3 sounds with a cam. Should be around 370HP to wheels.
    I still have to hand port the heads , perfect the tune, and add a turbo,flex fuel sensor etc.... But that will have to wait until I get more funds, xmas wiped me out!
    I'd do it again x100
