LS1 327 6 speed install questions
Discussion in 'High Tech Retrofits' started by Mrbrey1, Apr 1, 2012.
  1. camarochevy1970
    camarochevy1970 Veteran Member
    7,824
    69
    Jan 23, 2003
    Pittsburgh, PA
    Todd, you can get ls1/4l60 combos for under $3k. I have yet to find that deal with a t56
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  3. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Well. I am familar with the LS1, I happen to have two of them and one I had
    to yank the intake off to fix the coolant line underneath. The GTO they deleted
    this odd design flaw. I just have not installed one of them into a 2nd gen (I did
    not want the added hassle).
    One thing I will say about the LS1, I do like the intake manifold design. I have
    always hated the all inclusive intake/valve cover Chevy engine had. Its nice
    to see that after 47 years they caught up with Studebaker and separated the
    two. I never knew how spoiled I was growing up with Studebakers and that
    fuel-only intake design. I laughed when the "airgap" intake came out years ago
    for the Chevy V8, "Hey! Thats just like Studebaker!" (kinda - still one piece).
    Kudos to GM for finally getting that right. When I got the intake off the LS1 I
    had to take a picture of the valley cover.:)
    Tom
  4. patgizz
    patgizz Moderator Lifetime Gold Member
    12,737
    Apr 10, 1999
    Cleveland
    gm is still cranking out f body pans, because they know they get bought for swaps. i bought mine from the dealer. if the h3t pan(aka gm's universal rear wheel drive swap pan) was available at the time i'd have used it in my impala.
  5. camarochevy1970
    7,824
    69
    Jan 23, 2003
    Pittsburgh, PA
    Yep no fear of an fbody pan shortage anytime soon
  6. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    :) :) :) :) :) :) :) :) :) (54,000 MILES)
  7. JohnnyZ
    JohnnyZ Veteran Member
    107
    Sep 2, 2010
    IN
    Stock Truck manifolds will not work, you'll need F-body manifolds.
    A 5.3 is not that much cheaper by the time you get done buying intake and exhaust manifolds, accessories + accessory mounts, oil pan and water pump.
  8. Jones20992
    Jones20992 Member
    95
    Apr 30, 2012
    Casper wy
    The 5.3 is 325ci not 327ci
    if your going to keep it EFI be sure that if your doner motor has the knock sensors under the intake rather then on the side of the block to replace ther rear sensor and use the updated gasket as this is a big problem
    The 5.3 can make 400 hp at the crank with a cam and valve spring change but if you keep it EFI you have to change the rev limit do a search I believe Car Craft did a write up on it sometime last year
    Also if you get a 5.3 out of a monty SS or h3 alpha they are aluminum as well
    Just my 2 cents
  9. JohnnyZ
    107
    Sep 2, 2010
    IN
    GM Dubbed it the LS327 when used with a performance cam.
    http://www.jegs.com/p/GM-Performance/GM-Performance-Parts-LS327-Deluxe-Crate-Engine/1297510/10002/-1
    Its not the first time, nor the last that displacement numbers will be fudged to make a motor sound cooler. Ford 5.0 (302) was really a 4.9. '70 Camaro was called a "396" even thou it had a "402".
  10. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Scott from Hamilton, NJ
    I thought the FWD motors did not make good swap candidates?
