LS1 327 6 speed install questions
Discussion in 'High Tech Retrofits' started by Mrbrey1, Apr 1, 2012.
  1. COLS70-73MAN
    COLS70-73MAN Veteran Member
    342
    Sep 17, 1999
    COLS,GA U.S.
    The 5.3 can be bored to LS1 size, giving you an iron block LS1. My 2000 6 speed 3.42 gear factory stripper Z28 ran 13.30's with just a airbox lid when it was new. With SLP loudmouth, thermostat, filter, and sticky tire it ran 12.80's. I suspect it would still run those numbers with 127,000 miles on it. (I drive it every day) Point here is it's just fine to use a 5.3 to do a swap. You could upgrade to 5.7. or 6.0 later.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Only downsides to a 5.3L are the early one's were plagued with piston slap
    Later one's ate up a quart of oil frequently it seems I've read alot.
    So I dunno lately about the 5.3L swaps......that's one reason I went to the 6.0L
    I'm starting to believe the smaller truck motors weren't built as well.
  3. camarochevy1970
    camarochevy1970 Veteran Member
    7,824
    69
    Jan 23, 2003
    Pittsburgh, PA
    the 5.3's were fine. They use about the same amount of oil as an LS2 and as far as Piston slap shows, the LS1's were known for that too.
  4. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    My '06 Silverado has not given me a single problem as far as the engine is concerned, 99200 miles and does not use a drop of oil. I guess I'm one of the lucky ones?
