ls1 dynatech zbar
Discussion in 'High Tech Retrofits' started by 1977nova, Mar 30, 2013.
  1. 1977nova
    1977nova Member
    39
    Jul 19, 2005
    canada
    Has anyone ran an LS engine with the mechanical z-bar with Dynatech headers? If you have could you please post a photo of your setup.
  2. 73 L92
    73 L92 Veteran Member
    126
    Apr 4, 2012
    Carlos, MN
    I have on my 73. Made my own cross shaft and used rods for pivots.
    Works well. I need to resize the photo to attach.
  3. 1977nova
    1977nova Member
    39
    Jul 19, 2005
    canada
    Thank you for the answer. I figured I would need to mod the zbar. I just wanted to see how someone else did it so I can get a better idea. What did you use for the pivot ball on the block side?
  4. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,093
    Oct 14, 2007
    Waukesha WI
    what are you using for a trans?
  5. 1977nova
    1977nova Member
    39
    Jul 19, 2005
    canada
  6. RICARDO1969
    2,093
    Oct 14, 2007
    Waukesha WI
  7. 1977nova
    1977nova Member
    39
    Jul 19, 2005
    canada
    Nice build. What headers are you using?
  8. RICARDO1969
    2,093
    Oct 14, 2007
    Waukesha WI
    I don't have this car anymore i just thought the info might help you out.
    as far as headers go i never bought any for that car so cant help you there.
  9. RICARDO1969
    2,093
    Oct 14, 2007
    Waukesha WI
    You could always run a hydraulic clutch and avoid the headaches.
  10. 1977nova
    1977nova Member
    39
    Jul 19, 2005
    canada
    I want to run the mechanical setup. I have an idea how I want to do it. I was looking to see how other people did it. I mostly need to see how to route the zbar in regards to the headers. I think I just need to cut an move the one arm on the zbar and use the rod end linkage.
