ls1 engine swap
Discussion in 'High Tech Retrofits' started by 78rallysport, May 5, 2009.
  1. badazz81z28
    16,923
    502
    Las Vegas, NV
    I know what your saying but your not factoring in the LSx engine will be used not rebuilt Zero miles like the SBC is you compare to. Also the the camaro came with the SBC so the acc., headers, and other misc stuff will already be in hand and not starting fresh. I will do another look around...I prefer a manual tranny so the search will be a little tougher. I dont want to chop my trans tunnel again for the T56...I would like the shifter to poke through the stock hole...TKO maybe....
  2. jakeshoe
    8,881
    21
    Dec 8, 2000
    Republic of Texas
    I have NEW LS engines for prices from $2500-up.
    Build a SBC from ALL new parts for $2500 with aluminum heads and a roller cam....
    Try to do it with even a used block...
    Accesories are usually included on the wrecking yard LS engines.
    The idea here is that resourceful guys that have the necessary skills can improve their car using modern technology.
    If you aren't resourceful and/or don't have the skills, then it's probably not for you.
    T56 didn't require any significant tunnel mods when I installed one in my '72 Camaro. Cut the hole for the shifter.
  3. badazz81z28
    16,923
    502
    Las Vegas, NV
    What type of engine do you sell for $2500? I put a T56 in my last Z28 but I had to cut into the floor brace for the shifter. I wasnt too satisfied with that. Since my new Z is a 4 speed I will have to patch a gaping hole. Really dont want to do that. Especially because one day someone or I want to convert it back to stock.
  4. badazz81z28
    16,923
    502
    Las Vegas, NV
    Where are you located?
  5. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    My LQ4 Long block cost me $1,000 worth of traded parts. Someone offering a LQ4 for $2500 better have a 100% new motor.
  6. jakeshoe
    8,881
    21
    Dec 8, 2000
    Republic of Texas
    I sell the the LQ4s for $2500.
    That's a steal for a completely new engine.
    I'm located in North Texas, 5 minutes off I-35. One hour north of Dallas or Ft. Worth.
  7. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    No T-56, but I did the swap with a 4L60e and a GTO LS1.
    I did the parts list in the Hightech Retrofits sticky.
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I think I might be in contact.
  9. 1970camaroRS
    2,606
    Mar 4, 2001
    Everett, WA
    Hey Ace, what alternator mount is that?
  10. badazz81z28
    16,923
    502
    Las Vegas, NV
    Do you have the link? I didnt see a sticky thread by you.
