LS1 Fuel Pump in 79 Z/28 ?? Possible
Discussion in 'High Tech Retrofits' started by npersha, Mar 17, 2011.
  1. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    JJ
    Good info. I believe the 4th gen f body pump unit is 11 inches ( may compress more). In the vetteworks online install page, it states "The F-Body fuel pump assembly has about 1" height adjustability". I plan on removing the vent part of the tank just like you did. It looks like a good flat (surface) mounting position and I will use the new pump vent line. Question,did you have any space issues with the new pump or fuel lines or any rubbing on trunk?
  2. OldSchoolFormula
    OldSchoolFormula Veteran Member
    119
    May 26, 2004
    Livermore
    I run my tank down to the point where the fuel needle doesn't move if I wanted it to and have never had a problem - and I drive it pretty hard. Being that needle is always moving around becaus ethe gauge is 100% unbuffered, thats pretty low. The 4th gen fuel pump assembly can also be shortened substantially by cutting the bucket down in height. You have to remember that at all times that bucket is full of fuel. It works well.
  3. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    I'm obviously missing something about this bucket...
    Is the strainer completly enclosed IN the bucket? I have a handfull of vortec, dodge, etc and the strainer on all of them is outside the bucket. Got a picture?
    -- Joe
  4. PolarBear
    1,189
    Apr 24, 2008
    NJ
    In this picture you can see the pickup sock under the bucket. This is how GM is doing all the OEM stuff now
  5. BonzoHansen
    19,654
    910
    Jun 1, 2005
    Scott from Hamilton, NJ
    5th gen
  6. anesthes
    868
    Jun 17, 2009
    Salem, NH
  7. OldSchoolFormula
    119
    May 26, 2004
    Livermore
  8. Fbird
    4,322
    767
    Feb 12, 2011
    atlanta, ga
    OK.....you have definately explained why i'm confused! :confused: I just don't get it!
  9. Fbird
    4,322
    767
    Feb 12, 2011
    atlanta, ga
  10. reedld
    268
    Aug 9, 2007
    Painted Post NY
    ok..let me try...you turn the key, fuel pump starts up. It sucks fuel through the sock, the fuel is pressurized as it goes up and out of the tank...excess fuel, from the regulator, returns to the fuel pump bucket. keep in mind, this fuel has already been 'filtered' through the initial sock, so it does not need to be re-filtered. The return fuel DOES not go back in with the 'un-filtered' fuel. The fuel in the fuel bucket gets used up prior to new 'un-filtered' fuel being sucked up. This fuel bucket will hold enough fuel to run your engine without burning up the pump. I suppose if you were cornering for an extremely long time...like in a circle, you'd run out of fuel. This explanation is in simple terms...I have read that the fuel pump has a complex system of 'check balls' to help it not suck air in the tank. If the pump senses any air being sucked in, it closes up, as soon as fuel sloshes back, the check valve opens back up and continues to pump fuel. This process continues over and over. Ideally, the bucket is always full. Many people..much smarter than me, have stated that they have never opened an OEM fuel tank to find a complex system of baffles...just this 'fuel bucket'. I am glad I discovered this prior to buying the tanks inc kit..I think this system is simple and should work well.
    so...are you more confused??? hopefully not.. I am tied up for the next 3 weekends (UGH). I will be doing this real soon and hopefully positive results will prevail...
