LS1 Fuel Pump in 79 Z/28 ?? Possible
Discussion in 'High Tech Retrofits' started by npersha, Mar 17, 2011.
  1. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    The LSx (4th gen) fuel tanks are plastic, correct? SO you can't just cut the top off one and weld it to a 2nd gen tank?
    -- Joe
  2. firebird_ta79
    firebird_ta79 New Member
    16
    Jul 1, 2009
    Prince Albert SK
  3. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Correct. But someone in another thread cut out the top of a tank from another vehicle and welded that to the top of the Camaro tank, may have been from an Astro van?
  4. npersha
    npersha New Member
    16
    Sep 10, 2010
    Iron Ridge, WI
    Fuel Gauge
    FirebirdTA79:
    Do you know what the ohms resistance on the 98-02 F Body pump is for the fuel level gauge full and empty? I have read its different from the typical 0-90 GM style. Please let me know if you know this info. I have all aftermarket Autometer Pro comp gauges in my camaro, so I can just purchase a new fuel level gauge to replace my current one.
    Thanks Nathan
    Billnthemale likes this.
  5. OldSchoolFormula
    OldSchoolFormula Veteran Member
    119
    May 26, 2004
    Livermore
    Maybe this will help...
    I'm also not using anything above the bucket. I'm simply using the bucket which I shortened to fit the early tank, the fuel pump and associated jet pump venturi thing and not much else. Using the C5 fuel filter/regulator externally and my pump feeds fuel to a 3rd gen sending unit.
  6. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Its something like 40 to 240 or so
  7. firebird_ta79
    16
    Jul 1, 2009
    Prince Albert SK
    the stock sender is 40 empty and 240 full , that is reverse of what the auto meter gauge will read ( 240 empty 33 full ). to fix this I bent the top of the stock fuel float arm 180 degrees so that it reads the GM scale backwards. If you want some pics let me know.
  8. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    I plan on using the stock 1978 fuel float.. I don't feel like buying a new autometer guage. Can you tell me what color wires (from the 1999) control what?(fuel pump power, etc) Thanks
  9. Fbird
    4,192
    710
    Feb 12, 2011
    atlanta, ga
    ahhhh I see. The fuel pump screen is actually INSIDE the bucket! Now that makes sense. I was trying to figure how the stock pump was able to pull from 2 different locations in the bucket.....outside the bucket.....all is well now continue forth and conquer. :)
  10. 79zLT1
    79zLT1 New Member
    25
    Nov 15, 2010
    Rochester, NY
    Is this just the case for lsx fuel pumps or did they start it in the lt1?
