LS1 Fuel Pump in 79 Z/28 ?? Possible
Discussion in 'High Tech Retrofits' started by npersha, Mar 17, 2011.
  1. 1977nova
    1977nova Member
    50
    Jul 19, 2005
    canada
    I was also curious about the ls1 pump with the vetteworks kit hitting the floor?
    If it does hit, how much would I have to lower the tank to make it fit?
  2. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    Guys....I just completed the ls1 fuel bucket in a recessed tank...no trunk mods..
    I used the vetteworks kit, it is recessed about 1.5", no mods to fuel bucket except I shortened the internal fuel hose ( hose #10 in previous page drawing). I compressed the bucket as far as i could, as I played with compressing it...I realized the fuel hose kinked, so I shortened it. I bought a used fbody pump bucket...but wanted to put a new replacement pump in for piece of mind. Fuel bucket is real simple to take apart. I wanted to physically shorten it but I could not figure out an easy way. Some have talked about cutting the metal tubes and reflareing them.
    I started with a new tank and after the recess was welded in, I used a gas tank sealer product from KBS. Nice product. I was sure to coat the welds by rotating it completely. I am using the OEM fuel sender only because I do not want to buy a new autometer cobalt guage....mine is specific for 0-90ohms. I did have to bend the sender counterclockwise a bit to clear bucket. I thought I'd be ok without doing it....but I was wrong. I had to re-drop the tank and adjust it. While it was down, I inspected the bucket. Works like it should. It was partially filled with fuel...just like it supposed to.
    End result....quiet...and I have put almost 300 miles on it without any issues.
  3. ryeguy2006a
    ryeguy2006a Veteran Member
    157
    Sep 29, 2009
    Upstate, NY
    Looks great Leon!
  4. mtrhead79
    mtrhead79 New Member
    Nov 11, 2006
  5. la-rue
    la-rue Veteran Member
    437
    Sep 30, 2013
    SF Bay Area, Ca
    At $500+ or so after shipping, there are cheaper options out there. But that's not too bad.
