LS1 Fuel pump swap into 2nd gen tank
Discussion in 'High Tech Retrofits' started by anesthes, Nov 23, 2011.
  1. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    No, I'll spend some time on that tomorrow or tonight after I fill my belly with some turkey.
    I don't suspect there will be an issue, and if there is I'll just add another layer of foam over the two isolation strips.
    -- Joe
  2. anesthes
    868
    Jun 17, 2009
    Salem, NH
    No problem. You will see once you start working on it.
    As far as fuel pressure, there is a table in the $8D masks (90-92 fbody) that adjusts ve based on baro. It adds more fuel under vac (around 65kpa) and slowly tapers off until 100kpa (WOT).
    So this fuel table is the inverse of what the fuel pressure regulator does. My theory is that if the table were set to be the same in each cell, it would not compensate for the varied fuel pressure.
    -- Joe
  3. reedld
    reedld Veteran Member
    262
    Aug 9, 2007
    Painted Post NY
    Joe, nice explainaton.. Good to know ahead of time that the new pump will NOT fit in the vent area. I was planning on doing it that way. I'll cut a large rectangle out, put the vette works ring in and then attach the new metal to the tank. I'm curious to know how it will fit when the tank is raised up.
    I want to keep my existing tank unchanged just in case something goes wrong. It works fine....I just dont like the noise. I've put about 2500 miles .......
    Leon
  4. BLKnBad71Z
    BLKnBad71Z Veteran Member
    1,431
    Sep 20, 2000
    Buffalo,NY,USA
    If you want to do this on a old tank that had gas in it, you can send the tank to a rad shop and have it boiled out to get rid of all the gas and fumes. My buddie added a comp eng sump to my tank and we just cleaned it out good and he uses a ex hose stuck in the tank and runs a car to pump the ex fumes into the tank to get rid of any gas fumes when welding.
  5. anesthes
    868
    Jun 17, 2009
    Salem, NH
    You can also put dry ice in it 30 minutes before you weld it.
    I removed my tank in April, and drained it.
    Then I built a house over the summer.
    Now I'm back to playing with the car. So there was zero fumes. I wouldn't drain one at noon, and try welding at 1PM without SOME type of clean out :)
    -- Joe
  6. anesthes
    868
    Jun 17, 2009
    Salem, NH
    Updated picture.
  7. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
  8. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    Can you post the files to this site so we dont have to register at the other one?
  9. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
    Uh, I tried but file too big :mad: Sorry. oh well it is along the same lines as posted here, just with 24 bolts through the new flange, gasket, and into riv-nut inserts in the top of the tank.
  10. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    You mentioned that the later 2nd Gen tanks are "taller".
    Is this true rendering the modification you describe in this thread only applicable to later 2nd gen cars?
    Do you have a measurement of your tank height or a minimum height that would be required?
    Thanks.
