LS1 Fuel pump swap into 2nd gen tank
Discussion in 'High Tech Retrofits' started by anesthes, Nov 23, 2011.
  1. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    Around 9" is what you need. The later tanks are kind of odd shaped (see the picture) and I'm taking advantage of the "tall" side.
    I'm assuming based on what I've seen from pictures, and the fact that production specs say the later year cars had a higher fuel capacity that the tanks are at least 2-3" taller.
    -- Joe
  2. studsZ28
    studsZ28 Veteran Member
    115
    Feb 19, 2008
    MN
    Great post!!! I just did about the same thing for mine. Except I cut out the opening for the factory fuel sender as well, then fitted a sheet of 20 gauge steel and burned it in. Very happy with the results!! Thank you for doing it first and postin pics!
  3. reedld
    reedld Veteran Member
    262
    Aug 9, 2007
    Painted Post NY
    Joe,
    Have you completed the electrical connections? I know the fuel pump wires are grey and black (heavier gauge black)....the regulator connection has 3 wires...and it states 5 volts on the regulator. Can you help with any of this? Thanks
    I just purchased a new tank and want to get started on this.
    Leon
  4. anesthes
    868
    Jun 17, 2009
    Salem, NH
    You don't use the 3 wire connector. That is to report back to the ECM. It's to detect pressure changes in the fuel tank for the EVAP.
    -- Joe
  5. reedld
    262
    Aug 9, 2007
    Painted Post NY
    Thank you Joe.
    I'll be posting pic/ progress as it happens.
    Leon
  6. ReDDruM
    ReDDruM Member
    34
    Aug 4, 2009
    central california
    so this wont work on an early tank?
  7. anesthes
    868
    Jun 17, 2009
    Salem, NH
    Not tall enough.
    -- Joe
  8. jd_mcse
    jd_mcse Member
    52
    Feb 2, 2011
    Sunny, FL
    anesthes
    Based on what you remember of the return line internal baffle. Do you see any issues with using this vent line as a return line?
    Thanks,
    JD
  9. reedld
    262
    Aug 9, 2007
    Painted Post NY
    I did the swap last year.....I posted results somewhere...but obviously not on this thread.
    Here is my setup
    Center line is a vent..right most line is the return..hope this helps.
  10. 75Maro
    75Maro Veteran Member
    411
    17
    Mar 31, 2008
    Dallas,Tx
    Trying to revive an old thread here but do any of you guys have the wiring to pump done? I don't have a pin out of the 4 wire connector on the pump to know what needs power and so on, thanks for any help
