LS1 hydraulic clutch setup
Discussion in 'High Tech Retrofits' started by 78camaro53, Jul 30, 2016.
  1. 78camaro53
    78camaro53 New Member
    26
    Jul 25, 2016
    Lansing,MI
    Thanks badazz81z28
    Do you by chance have the wilwood mc part no: ???
  2. 81Z28LS
    81Z28LS New Member
    Dec 16, 2018
    Hey 78Camaro53, can you give an update as to which hydraulic parts you went with and did you use the Speedtech bracket? Have you been happy with your setup? I have an '81 Z converting from auto to either a TKO 600 or T56. Thanks for any advice!
  3. badazz81z28
    15,629
    252
    Las Vegas, NV
    81Z28LS likes this.
  4. 81Z28LS
    81Z28LS New Member
    Dec 16, 2018
    Nice and clean! Where did you buy the mounting bracket? It looks great.
  5. TCinthe6
    TCinthe6 Member
    67
    8
    Nov 5, 2017
    Toronto, Canada
    I don't know if this has changed over the last couple of years...but I ordered the McLeod master cylinder kit, and the master is actually Willwood.
  6. Roggie
    Roggie New Member
    22
    Jun 24, 2014
    United States
    I'm running the stock F-body MC, and I bought the Detroit Speed bracket for the firewall. Decent part, but had I known about the speedtech setup, i would have bought that. The DSE setup just tells you to grind the push rod of the MC apart, cut it, and reweld it. The adjustable heim that Speedtech sells is a MUCH better solution.
    The DSE kit called for a 1/2" chunk to be removed... I ended up removing ~.600" by mistake... if that puts me in a bad spot, nothing i can really do without adjustability.
  7. Happy_Dan
    Happy_Dan Veteran Member
    799
    123
    Sep 13, 2013
    New Boston, NH
    The only thing I can add to this as a fourth gen owner is that the stock clutch master is known to have issues when pushed (currently mine has the pedal sometimes stick to the floor and I have reach my foot under and pull it up) and also put a remote bleeder on the slave because you can't get to it to bleed it.
  8. 76z28
    76z28 Veteran Member
    1,744
    Jun 29, 2009
    bakersfield
    Wasn't that mostly due to restrictions in the actual line? Doesn't the drill mod take care of that?
  9. Happy_Dan
    799
    123
    Sep 13, 2013
    New Boston, NH
    I believe that is true but I remember reading somewhere that there is a better system out there now.
    Here is what I had from a friend:
    Dan - I was having this issue and when I upgraded my clutch a few years ago, I went with this upgraded master cylinder to solve the issue. I haven’t had the problem since.
    https://www.tickperformance.com/tick-pe ... ebird-ls1/
    They also make a super nice remote bleeder that I installed, makes it really fast to flush the fluid.
    https://www.tickperformance.com/tick-pe ... ntiac-gto/
  10. 76z28
    1,744
    Jun 29, 2009
    bakersfield
    Ah okay
    After some research I am going to with a wilwood or tilton master cylinder with OE slave cylinder and a remote style bleeder like that. I will be using a McLeod conversion line too.
