LS1 into '72 Camaro, Let It Begin!
Discussion in 'High Tech Retrofits' started by AndrewT, Aug 19, 2011.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,389
    83
    Feb 2, 2008
    SF
    Hi Andrew I was wondering what motor mount plates you used and did they require any modifications or where hey pretty straight forwards?
    Brp hot rods swears their package is the best
  2. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    I used the Dirty Dingo mounts. They required no modifications that I can remember and just bolted right up. You attach the factory or aftermarket mounts to them and they go to the bases that are on the frame.
    If I remember I'll take some pictures of them while the engine is still in the car tomorrow for you.
  3. 72BIGBLOCK
    2,389
    83
    Feb 2, 2008
    SF
    Thanks a lot I would really appreciate it I actually came across an LS motor but I'm still thinking if it's worth all the headaches.
    I keep thinking ls swap =equals more money but also more time
    Or just get a crate motor from GM performance and drop in and go ...
  4. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    Here are a few pictures of the Dirty Dingo mounts on my engine mounts on the frame.
    If I had the money I probably would have gone with an LS2 or newer in this car; don't think I could ever afford to drop a crate into it though.
  5. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    I was just advised today that I have access to the full brake system from a 99 WS6. So now I need to start researching how to use those parts to give my Camaro four wheel discs. Let the hunt begin!
  6. badazz81z28
    17,138
    553
    Las Vegas, NV
    That's always the case. If you had an LS2, you would wish you had the LS3.
    For what its worth, I have an LS1 and makes over 500hp. I have a guy at my work that had a modified LS2 GTO, and yup my car was faster.
    Nothing wrong with an LS1. My next engine will be a LS7.
  7. 72BIGBLOCK
    2,389
    83
    Feb 2, 2008
    SF
    thanks for sharing
