LS1 into '72 Camaro, Let It Begin!
Discussion in 'High Tech Retrofits' started by AndrewT, Aug 19, 2011.
  1. schitzo
    schitzo Veteran Member
    1,300
    Feb 12, 2005
    Minneapolis MN
    The covers clean it up nicely.
  2. jerhofer
    jerhofer Veteran Member
    490
    Jun 4, 2009
    Rockwell, NC
    Nice clean look.
  3. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    Thank you. I tried looking for ones that said Camaro but nothing looked as good as these while still saying 5.7L or something related to an LS1
  4. Burt
    Burt Veteran Member
    453
    Feb 17, 2005
    Far Northern CA., USA
    As I said above, the Corvette covers are right on. You engine isn't out of a Camaro or a Trans Am, etc, so you are telling it like it is.
    Jim
  5. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    I picked up a ECM today from LKQ and have a TAC module going to be here sometime next week.
  6. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    Picked up the TAC module from LKQ today.
  7. Burt
    Burt Veteran Member
    453
    Feb 17, 2005
    It looks like you have pretty well collected just about everything you need to get this all rolling. I can't wait to see it come together.
    Jim
  8. usmcz28
    usmcz28 Veteran Member Lifetime Gold Member
    382
    Jun 19, 2005
    Rochester, NY United States
    looking good
  9. AndrewT
    AndrewT Member
    61
    May 22, 2010
    Redding, CA
    Thank you. Been a little bit since I've updated... Not much has been going on with the build, just waiting for the transmission to be built.
    I've decided I'm going to run a 60 segment on the engine with the proper codes and tables edited, etc with the correct relay setup to swap the solenoid firings on the transmission. I've found a 4L80E to 4L60E conversion cable with the correct relay system for this type of swap but my harness is an M6 harness. I emailed the seller and once I get the transmission and can check the lengths I need he's willing to provide me with a pigtail as opposed to the 60 connector so I can just pin them into my PCM connecter accordingly. Aside from that I've just been playing the waiting game.
  10. Burt
    Burt Veteran Member
    453
    Feb 17, 2005
    Thanks for the update. This is a very interesting project. What are your plans for the fuel system?
    Jim
