Ls1/Lt1/and t56 on 80 camaro
Discussion in 'High Tech Retrofits' started by Camarocore, Feb 21, 2006.
  1. Camarocore
    Camarocore Veteran Member Lifetime Gold Member
    595
    Feb 18, 2006
    NY
    Hey
    im serching of ideas how to make powerfull street car
    http://www.nastyz28.com/forum/showthread.php?t=42473
    what you guys think about Ls1 or Lt1 swap?
    i thought also to swap the gearbox to t56.
    what will be more easy to swap and also what will be more easy to mod and make more HP output from.
    Thanks.
    Koby.
  2. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    Easiest-LT1....follows the traditional mounting points
    Most powerful-LS1....need a kit to mount it, but the power is limitless ;)
  3. Camarocore
    595
    Feb 18, 2006
    NY
    where i can find this Kit?
    and also any good sites with the same project?
