LS1/T56 in a 79 Z-28 Auto
Discussion in 'High Tech Retrofits' started by Jordan Williamson, Jul 31, 2018.
  1. Jordan Williamson
    Jordan Williamson New Member
    Jul 31, 2018
    Sorry if I'm beating a dead horse so feel free to just post links to other threads that you know of. I have a 79 z-28 I am ls swapping. I also have a complete 99 z28 I am using as a donor (drivetrain, brakes, everything). For the most part,I know what I need to do motor-wise for the swap but I keep finding mixed results for the trans info (Crossmember, cutting trans tunnel)
    My 2nd gen has a 383/th350 now with a 12 bolt and 3.73's
    What are yall using for the crossmember and what console works best?
    Should I use the 79 or 99 driveshaft
    What are some of the biggest issues you have? IMO the hardest part will be hooking up/mounting the slave/master cylinder and pedals due to the auto firewall.
    What additional parts will I need that I can't get off my donor.
    Headers Recommendations?
    Side notes: I plan on using Dakota digital gauges and not running AC currently
  2. ZEN357
    ZEN357 Veteran Member
    363
    63
    Feb 12, 2018
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,342
    78
    Feb 2, 2008
    SF
    Here’s what I did on my 69 Camaro swap and I also had the donor car
    I used the engine, harness trans and the radiator from the donor car.
    I sold the harness and I think I sent the computer to affordable efi and their reflash came with another computer plus I also used the computer holder from the donor car.
    The motor/trans mounts I got from brp but they are expensive however they sit the motor just right at least to me and allowed me to put the engine with a t56 with only minimal cutting for the shifter.
    If like the way it’s centered
    The radiator and the fans I used from the donor car
    I also used most of the wiring from the starter and battery off the donor car.
    The shifter came from summit they have a few options.
    The console will probably have to be pushed back almost 4 inches if I remember correctly
    The gauges have options now, there’s a company on eBay who makes some digital ones for about 250-450 depending on the deal
    I used the Holley pan but I think your pan will clear because your linkage is in the back.
    For fuel I used the tanks inc with in tank pump and the fuel line I got on eBay. I think I bought 25 feet
    That’s all I can pretty much remember for now since this was a while ago
  4. 1980RS
    1980RS Veteran Member
    3,022
    451
    Jun 17, 2006
    MN
    You will need a custom driveshaft for your T56 as it's even longer than a Turbo 400 so a shorter driveshaft is in order for that swap. I did this in my 68 Bird and thought a 4th gen would work but it was 3.5" too short. Looks like for the 1st gen is around 45" center to center of the u-joint caps, most likely a little longer on a 2nd gen car.
  5. badazz81z28
    16,178
    377
    Las Vegas, NV
    The stock sec gen driveshaft is like 48”. For a T56 swap I was using the mustang 45.5” driveshaft. It was a little short...46” would have been better.
    A stock 4th gen is like 42”. Not gonna work in the 79
