LS1 vs LQ vs efi 383?
Discussion in 'High Tech Retrofits' started by dentaku, Jun 12, 2012.
  1. dentaku
    dentaku Member
    32
    Feb 2, 2011
    Dallas, TX
    Agreed,
    So lets say i get a pullout lq4 motor with accessories and computer, What swap bits will i need to buy? So far here is my list of what i think i need to get it fit inside the car and running
    Ls6 intake - do i need new fuel rails/injectors with this? will the truck TB bolt up to this? and if i do get new injectors im pretty sure i will need the adapters to use them with the truck wiring harness.
    kwik brackets - to retain all accessories
    Does anyone know about using an AC system with an LSX? do i need to get an aftermarket system, or is it possible to hook the compressor up to the existing system? Is the factory system up to the heat of texas in the summer?
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Start reading. Been asked a million times.
    http://ls1tech.com/forums/conversions-hybrids/1446712-lsx-engine-swap-guides.html
    Start reading. Been asked here a million times.
    http://www.nastyz28.com/forum/showthread.php?t=38430
    What you don't find in there, search, and if you don't find it, then ask. :)
