LS1 Wiring question??
Discussion in 'High Tech Retrofits' started by scotts72, Mar 24, 2020.
  1. scotts72
    scotts72 Member
    82
    Mar 14, 2012
    Cleveland, Ohio
    Hi Guys!
    I was doing some general maintenance on my LS1 equipped 72 and I luckily came across some ground wires that were partially burned up..
    The odd part is that I cant seem to find either of these wires on my LS1 wiring diagrams, one is grey/white and runs down to a sensor that is attached to the right hand side of the oil pan.. Google search indicated that it is for a Oil temp sensor, but it does not appear in my diagrams.... the other one is black/white and I cant tell where the heck it goes.. the only black/white wire that is listed is for the #5 fuel injector but a resistance test tells me that this is not my wire..
    I would just like to confirm that these 2 wires are in fact supposed to be grounded before I replace them and have it happen again.. BTW, these 2 wires were landed on the same source of ground if that makes a difference..
    Any help with this would he greatly appreciated!!!
    TIA,
    Scott
  2. badazz81z28
    17,340
    596
    Alabama
    The LS1 didn't have a oil temp sensor. There was a oil level sensor that's deleted in alot of harness modifications. On my stand-alone harness, there are only few grounds and they are all solid black wires about 14-16 ga.
    Did you modify the harness your self? Where are these wires poking out from?
  3. scotts72
    scotts72 Member
    82
    Mar 14, 2012
    Cleveland, Ohio
    Yes, I modified it with help from a friend, but it's a stock 2002 harness.. it looks like both of them come out of the ECM then split off about a foot upstream from it.. I will grab a pic of it in the morning..
  4. Pierre74LT
    Pierre74LT New Member
    13
    Dec 28, 2012
    Qc
    you have a black and white ground for oil level (image from 2002 camaro)
