LS2 Belt Squeak...
Discussion in 'High Tech Retrofits' started by kboxx, Apr 24, 2012.
  1. kboxx
    kboxx Veteran Member
    149
    Dec 12, 2010
    Bellingham, WA
    I have a LS2 with the the Kwik alternator and AC relocation brackets. Since I've had the car put together, I've had an intermittent serpentine belt squeak that is driving me completely crazy. I've replaced idlers, rebuilt the alternator and am really not sure what to try next. The alignment is perfect. If I add pressure to the tensioner the squeak stays. It does not get any worse or better it seems with the AC on or off. Any thoughts?
  2. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    896
    Oct 22, 2005
    Niceville, Florida
    I had the SAME problem, also with the Kwik brackets. I tried different belts, etc. with no success. Alignment LOOKED perfect, but a couple of washers to bring the whole Kwik assembly forward about 1/16" fixed it and it hasn't squeaked since.
    I contacted the Kwik people. They were very helpful, sent some info and links on the subject.
  3. kboxx
    149
    Dec 12, 2010
    Bellingham, WA
    Thanks Daniel - I will give that a try. I've also replaced belts and such and nothing else seems to be helping.
  4. JJFarmer
    JJFarmer Veteran Member
    2,445
    Jun 28, 2002
    Lenoir City, TN
    Same squeak here too
  5. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    It's an alignment issue. Notorious with aftermarket brackets.
  6. CopperTop
    CopperTop Veteran Member
    300
    May 18, 2004
    Mass
    Same here...sucks to pull into a show with it squeaking....lol
  7. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    I have the same problem with my Kwik A/C bracket, except not only with a squeak, but also with the belt moving forward on the crank pulley off one rib. Alignment looks perfect on all the pulleys. I kind of wonder if mine is too far forward?
  8. 1970camaroRS
    2,606
    Mar 4, 2001
    Everett, WA
    The belt should walk towards the direction of misalignment. So, yeah, I bet yours is too far forward.
  9. 7T3LS1
    7T3LS1 Veteran Member
    193
    Mar 15, 2008
    Tustin, CA
    I had the same problem. I replaced the belt, idler pulley and tensioner. It still squeeked, really bad at times. Finally, figuring something had to be out of alignment even though I couldn't see it, I completely dissembled the Kwik brackets and reinstalled/retorqued to make sure everything was right. It was much better but still not completely fixed. Then I installed a Goodyear Gatorback belt at someone's suggestion and the noise has been gone for six months now.
  10. sbca96
    sbca96 Veteran Member
    2,883
    Oct 25, 2004
    Santa Barbara, Ca
    I have chased a belt squeak on my wifes 1999 Camaro SS since we got it, each
    time I fix it, something else starts squeaking. When we got it, it was the idler
    puller and the tensioner pulley. Then, a year later it was the idler pulley and the
    tensioner pulley on the A/C belt. At the time there was NO aftermarket part so
    I re-greased them and it quieted them up (some). They started doing it again
    and I revisited the part search and there was on available (Dealer was like $80
    a pulley when I checked the first time). I put the 2 new pulleys on and quieted
    it up again. Then about a year later, it started squeaking again. Back under the
    car and I find the freewheel bearing on the A/C pump is squeaking. Just changed
    that one out a weekend ago and its quiet again ... for now.
    The GTO hasnt made a peep ... yet.
    1999 Camaro SS : 210,000
    2004 GTO 130,000
    Never had that much trouble with my LT1 powered cars. Just a single tensioner
    on the LT1s in the 1993/1995 Z28s and the 1995 Impala SS, and the A/C bearing.
    1993 Camaro is over 260k now, 1995 Camaro made it to 192k (totaled) and the
    1995 Impala SS has 237k now.
    Yes .. I have too many cars. Anyone want an IROC?
    Tom
